Bike won't turn over - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-14-2007, 07:32 PM Thread Starter
It all started after I re-installed a set of carbs I was rebuilding. The Bike won't turn over with the start switch with the bike in neutral or with the clutch pulled in and it doesn't have any spark to the plugs when I bypass the starter relay. The starter does turn over. I replaced the main fuse and checked any connections I may have hit trying to get the carbs back in. The only thing electrical I even got close to was the switches on the choke site of the bars. All other electrical items do work ie.. horn, signals lights.
I believe it is something with one of the safety switches.
Any help it greatly appreaciated and needed... I want to ride..
jobrien is offline
post #2 of 12 (permalink) Old 03-14-2007, 07:52 PM
HAWK
Ccspinner's Avatar
Did you check the switch on the kickstand.
Or the run switch on the right hand.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 12 (permalink) Old 03-14-2007, 08:12 PM Thread Starter
I wouldn't think the kick stand would matter because it does it in neutral also. The run kill switch was good last week when I took out the carbs. I will bypass it in the morning. Also I have jumped the connections going into clutch side with the same results. But like you said if it is the kill switch then I would lose start and fire. correct.
jobrien is offline
post #4 of 12 (permalink) Old 03-14-2007, 08:17 PM
HAWK
Ccspinner's Avatar
I have never triet to jump the starter with the killl switch off.
Looking at the wiring schematick the kill switch is in line with the ignition switch so I would say yes.
Chad Falstad "Hawk"
Vroc #17649
post #5 of 12 (permalink) Old 03-14-2007, 08:36 PM Thread Starter
I bypassed the kill switch with same results. Should there be 12 volts at the kill switch? I couldn't find any voltage at the switch with the ignition on
jobrien is offline
post #6 of 12 (permalink) Old 03-14-2007, 09:14 PM
Sky Rider's Avatar
Check your main connections under the seat. It sounds like one of the connecting plugs is partially disconnected.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #7 of 12 (permalink) Old 03-15-2007, 04:26 AM
If the kickstand switch is stuck, it won't start in neutral.
That's one of the first things I'd check out.
post #8 of 12 (permalink) Old 03-15-2007, 06:30 AM
Taras_s's Avatar
As for my bike, it starts on kickstand(I think it depends on bike's years).
I agree with Sky Rider it's in connection problem, You should connect voltmeter to start button and shake every connector,fuse and every thing in ignition chain antil you see the right volts on meter.
Taras Stets
86' VZ750
Varta 18 Ah
don't wont,but need to R/R relo,
Ukraine, near Kiev
Taras_s is offline
post #9 of 12 (permalink) Old 03-15-2007, 11:40 AM Thread Starter
Thanks to all, Problems solved.. It appears that the connecter from the kill switch harness got disconnected behind the front coil. Could have happened we I pulled the chock cable through for the carb work.
Also my bike will start with the kick stand down in neutral or with the clutch pull in.
Another think to note that maybe should be in the carb section is that my bike will only run right if the vent hose is pointed forward. Not back under the tank and for sure not going in to the hole behind the air filter (and yes i did cut it at 45 degrees). Don't know if that might have be the problem the whole time or not, but at least I know my carbs are good and assemble correctly (unlike the person who owned the bike before me).
Also another question. If you take 10 pounds of crab (18 gauge wire from Kawi) and stuff it in a 5 pound bag (location behind 1 coil and headlight) how much crap to you really have.
Again thanks to all especially Ccspinner who had me look at the kill switch first.
jobrien is offline
post #10 of 12 (permalink) Old 03-15-2007, 09:14 PM
HAWK
Ccspinner's Avatar
Glad you fund it.
Chad Falstad "Hawk"
Vroc #17649
