A Couple of Electrical Questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 03-11-2007, 07:48 PM Thread Starter
Crobins365's Avatar
With my some of my dash lights out, and suggestions from folks to check the connections up at the dash/headlight wiring harness, I decided to...start from the back. Been checking all connections, pulling old electrical tape, and - much to my surprise - am finding wires that are in not-great shape and were sealed by some previous owner. Am bidding on a 2000 harness on eBay, but meanwhile am rewrapping the harness, sealing broken wires, etc., etc. Questions, though: is it possible to get the six-lead or four-lead connectors someplace pleb, like AutoZone? I went to Pep Boys today, and they didn't have anything, but maybe I can find them somewhere other than at Ayers? Just some of my mulit-wire connectors are (surprise again) broken or cracked and I'd like to replace those. Second, what gauge wire is standard on our bikes? I'm guessing it's somewhere between 18 and 22, but maybe it's not that small.
Thanks.
C
Crobins365 is offline
post #2 of 22 (permalink) Old 03-11-2007, 07:57 PM
93VN750's Avatar
Cindy -
I have replaced several connectors on my bike with trailer harness connectors. You can get 2 pin, 4 pin, and 6 pin versions. They make a good connection, are water resistant, and inexpensive.
Original factory connectors are going to be expensive and a paain to work with.
Most likely, it will be very hard to properly crimp the terminals without the special tool used by the factory.
As a suggestion, these (http://www.etrailer.com/faq/wiring.aspx) are the ones I have used. A couple of bucks at any automotive store. A couple of butt splices, a wrap with electircal tape, done.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 22 (permalink) Old 03-11-2007, 08:23 PM Thread Starter
Crobins365's Avatar
So you're using those for things like the connection between the harness and, say, the reserve lighting unit? Or the wires coming off the harness up by the headlight and hooking into the main harness (up by the ignition coil under the gas tank)? They look really nice -and a whole lot sturdier than the OEM ones.
THanks, Jon!
C
post #4 of 22 (permalink) Old 03-11-2007, 08:28 PM
93VN750's Avatar
THanks, Jon!
Cindy -
I'll use them for anything other than the yellow stator leads.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #5 of 22 (permalink) Old 03-11-2007, 08:30 PM Thread Starter
Crobins365's Avatar
Hmmm...but these won't fit onto the juntion or ignitor box, right? Or is there something I'd need to do to make 'em work? That's where my problem is right now - the connectors to both of those units are in questionable shape. I don't know whether to epoxy 'em or what. But I could definitely replace all the other connectors with those on the web site. THose look really nice.
C
post #6 of 22 (permalink) Old 03-11-2007, 08:59 PM
Growling at the World...
bulldog485's Avatar
Send a message via Yahoo to bulldog485
Thanks.
Cindy,
If you do not win that harness, let me know. I have one hanging up in my garage that I was going to use on my VN750 but can be convinced to let go.
Evan Breyn ~ The Bulldog
http://www.bulldogsbike.com
2006 Harley Davidson Ultra Classic FLHTCUI ~ The Big Black Bitch ~ 26,000 miles.
2002 Kawasaki Nomad 1500 ~ The Red Dog ~ Traded in at 22,000 miles of smiles (purchased new 10/05 / Traded in 6/12).
1990 Kawasaki Vulcan 750 ~ Black Betty ~ 34,999.7 miles
VROC ~v~ 485
McHenry County Road Pirates
Chicagoland, IL
bulldog485 is offline
post #7 of 22 (permalink) Old 03-11-2007, 09:10 PM
Benjammin'
BSkaggs513's Avatar
Question....
Evan,
Are you the one who makes the powder coated R/R bracket to relocate it? If so, do you have any in black available? That is a spring project that I am behind on.
Thanks.
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #8 of 22 (permalink) Old 03-11-2007, 09:14 PM
bulldog485's Avatar
Originally Posted by BSkaggs513 View Post
Evan,
Thanks.
I am. I have 10 made up waiting for me to get off my lazy ass and powdercoat. Now that Spring has sprung I can get back into my garage and get some work done. Soon...
VROC ~v~ 485
Chicagoland, IL
post #9 of 22 (permalink) Old 03-12-2007, 07:05 AM Thread Starter
Crobins365's Avatar
Originally Posted by bulldog485 View Post
Cindy,
Thanks, Evan. I did manage to score the harness off of eBay, so I'll see how that does me. But I appreciate the offer!
C
post #10 of 22 (permalink) Old 03-12-2007, 08:32 AM
Taras_s's Avatar
Thanks.
I'd said min 16 or even 14, as for headlight the are biger.
Was cutting them yesterday.
Taras Stets
86' VZ750
Varta 18 Ah
don't wont,but need to R/R relo,
Ukraine, near Kiev
Taras_s is offline
