electrical schem searching? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 03-07-2007, 04:25 AM Thread Starter
Taras_s's Avatar
In mine .pdf manual it's not shown correctly.
There is no light and tachometer don't work, going to check fuses.
Warmed engine stops when I ride, I don't know why, may be cous' of electronics.
Taras Stets
86' VZ750
Varta 18 Ah
don't wont,but need to R/R relo,
Ukraine, near Kiev
Taras_s is offline
post #2 of 12 (permalink) Old 03-07-2007, 05:00 AM
Do you mean no headlight, or light inside the tach?
Don't want to worry you, but my headlight quit working when the stator went out. The tach was working though.
post #3 of 12 (permalink) Old 03-09-2007, 04:42 PM Thread Starter
Taras_s's Avatar
Headlight is ok, no light inside the tach, and now the tach dont working, need el. schem or give me a link to it... I rod about 60 km generator is ok, but tachometer don't work.
Taras Stets
86' VZ750
Varta 18 Ah
Ukraine, near Kiev
Taras_s is offline
post #4 of 12 (permalink) Old 03-10-2007, 02:34 AM
An electrical diagram is available HERE. It's an EXTERMELY large PDF file. The diagram for the tach light is on page 303 (page for "Other than US & Canada" bikes).
Hope that helps.
post #5 of 12 (permalink) Old 03-10-2007, 03:54 AM Thread Starter
Taras_s's Avatar
That's the point, I already have this manual, but electric schem wasn't apears corectlly - so I wasn't seen anything. Now it's ok I re-install my acrobat, and know I see the schem.
In home it was hard to download new manual(I've think that mine was damaged), couse' 1mb ~ 1$ to me, I conect to internet by mobile phone.
Now its ok. I have a schem and try to find what wrong with my bike.
Taras Stets
86' VZ750
Varta 18 Ah
Ukraine, near Kiev
Taras_s is offline
post #6 of 12 (permalink) Old 03-10-2007, 06:59 PM
Oh, I understand. Glad you have it correctly now
Hope that you get it all figured out.
Be sure to note that some of the diagrams are for US and Canadian bikes, and others are for other countries.
I'm just guessing, but most of what is different would probably be that the headlight isn't on all the time that the bike is running. Might be some other things too, but that is all I can think of.
post #7 of 12 (permalink) Old 03-12-2007, 06:17 AM Thread Starter
Taras_s's Avatar
I find a problem. It was a new headlight case - it cut wires ~ 8 of them, though tachometer inside light wasn't work first, at second tach stop work it self.
I repair this, connect wires, everything work, exept engine. :-)
Taras Stets
86' VZ750
Varta 18 Ah
Ukraine, near Kiev
Taras_s is offline
post #8 of 12 (permalink) Old 03-13-2007, 08:28 AM Thread Starter
Taras_s's Avatar
What does it mean when neutrial and oil pres. sensors is blinking( I mean: 1 second -normally, next second- low level of light, and again normally ...)?
Key is on, ignition off, lights off.
And when engine works on idle rpm's, turn on headlight and push brakes - engine stops.
I wonder what should i check first?
Taras Stets
86' VZ750
Varta 18 Ah
Ukraine, near Kiev
Taras_s is offline
post #9 of 12 (permalink) Old 03-13-2007, 01:38 PM
Sky Rider's Avatar
Sounds like some more wires may have been crimped or cut in the headlight case. I'd start there.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #10 of 12 (permalink) Old 03-14-2007, 10:33 AM Thread Starter
Taras_s's Avatar
I think so too, but I check every wire in headlight case and haven't seen something wrong.
I'm going to add some idle rpm's -thinking of, when turn on lights and stop signals - the voltage becomes lower level and ignition stops working, but when I give him a little throtle the generator start produce sufficient ampers to system to work.
Tachometer isn't show precislly how much rpm's is 900 or 1100, right?
Taras Stets
86' VZ750
Varta 18 Ah
Ukraine, near Kiev
Taras_s is offline
