Where to get a new battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-05-2007, 02:05 PM Thread Starter
Question Where to get a new battery
I am having trouble stasrting my bike in the cold weather. Had to jump it severel times. She fire up nicely when it's above 50ish, but wont start below. Does anyone know where I can find a battery with some decent cold cranking amps?
piromedicx is offline
post #2 of 10 (permalink) Old 03-05-2007, 02:18 PM
93VN750's Avatar
Got my AGM from batteriesplus.com, but picked it up from a local locations of theirs.
This http://tinyurl.com/yzpq6k is the one I got.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 10 (permalink) Old 03-05-2007, 05:51 PM Thread Starter
Jon
Thanks again
post #4 of 10 (permalink) Old 03-05-2007, 08:38 PM
Calif Rider
weh44att's Avatar
Try ebatteriestogo.com. they have what you want at a good price. It is a jell battery and is same size as the original. When I bought mine there was no shipping or tax on the item. It may still be the same.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #5 of 10 (permalink) Old 03-05-2007, 08:41 PM
93VN750's Avatar
Pretty sure the original was a acid based, wet cell type. Kaw wasn't going to spring for AGM type batteries.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #6 of 10 (permalink) Old 03-07-2007, 12:02 PM
fergy's Avatar
Measure your voltage on the red wires on each coil with the key on and engine not running. They should be very close to the voltage across your battery again with key on engine not running. If there is a substantial voltage drop to the coils, it's probably not going to get much better with a new battery, although replacing your wet cell with a sealed gell is still a good idea. You might have corroded connectors or just bad, old wiring causing your voltage loss. The coil wiring mod in my sig would help if this is true on your bike.
Another thing that might/should help is to go with the iridium plugs. They take less voltage to create a hotter spark, which is what is needed on those cold mornings. Even with the coil mod, my bike was getting hard to start on cold/damp mornings after it had sat for a few days. I put in the iridiums and that completely went away. Usually starts on the first noise of the starter now, might take two bumps once in a while, but never three.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 10 (permalink) Old 03-08-2007, 09:51 AM
Get a Westco battery. I have one for my VN750. It starts like a charm, replaced the stock battery after I had the bike one month and joined vn750.com. Just ordered a Westco for my Buell today, darned thing wouldn't crank this morning so I rode the Vulcan...
Glad I did, pretty day, and the bike looks so pretty parked in the new parking lot at work from the window... I know the Asphalt won't get hot, but it's less than a month old so I stuck a kickstand critter under the kickstand.
Only issue is disposing of the old battery, I still have the old Yuasa from when I got the Vulcan, the HD battery (also a Yuasa) has to go when the new one comes in. Found out our county has recycling centers which will take them.
Stephen
Maumelle, AR
AMA Extra Mile Member: 213475
[ '03 Buell Blast | '05 VN750 ]
www.mrbun.com
Mister_Bun is offline
post #8 of 10 (permalink) Old 03-08-2007, 02:23 PM
Any place I've ever got a battery from adds a core charge to the new battery, which is returned to ya once you bring the old battery back to them. Usually about $5-$8.
post #9 of 10 (permalink) Old 03-08-2007, 10:53 PM
Sky Rider's Avatar
The Westco's seem to have an early failure rate. Several here have posted that thiers failed prematurely. Just a heads up if you run into any trouble.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #10 of 10 (permalink) Old 03-09-2007, 02:43 AM
I didn't think about online purchases when I posted my above post.
It would be a pain to send a junk battery back to an online merchant for a few dollar core charge
