Restoring a train wreck help !!!!!!!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-08-2013, 11:42 AM Thread Starter
We bought this bike, my wife rebuilt the carbs and we got the bike started, but the R/R wires were cut and a larger R/R is in it's place, might this be why the battery is draining or discharging ? if anyone has any suggestions please write I could use all the help I can get, thank you.
rkama354 is offline
post #2 of 5 (permalink) Old 07-08-2013, 12:03 PM
Okiebezer's Avatar
Looks like the PO may have tried to correct an issue with the changeout. I would start by checking all connections for contact viability. Clean all grounds as well. You can get some dielectric grease at local auto box store (Autozone, Advanced, etc.) to help keep connections from getting gunked up once cleaned.
How old and what type is the battery?
Malibu Shades windscreen, headlight visor, custom dashboard with voltmeter and clock, luggage rack, extended backrest, Viking saddlebags and toolbag, Wingerline engine guard with foot pads, light bar with halogen bulbs, Hardley Sportster muffs with crossover, homemade coasters, earshave with K&N pods, 142/42 jets with 2 shims each needle, MCCT's, AGM battery, coil relay mod, Iridiums with yellow NGK plug wires, relocated R/R, WOLO air horn, VN750.com chrome radiator guard
Okiebezer is offline
post #3 of 5 (permalink) Old 07-08-2013, 12:11 PM
The larger R/R is probably a good thing.
0) Test and charge the battery. Check all connections.
1) Run through the electrical tests stickied in the electrical section. You want to do a full work-up of your stator and R/R.
If everything is wired properly, I am betting your stator went south and he didn't feel like repairing it.
post #4 of 5 (permalink) Old 07-08-2013, 04:17 PM
You could go here:
http://www.roadstercycle.com/
...and see if it looks like you have the MOSFET R/R.
If you do have the MOSFET kit, go here:
http://www.roadstercycle.com/Easy%20...%20Install.htm
... check the drawing and see if it's wired correctly. The MOSFET wiring should completely bypass the factory R/R wiring, with the stator wires running directly to the R/R and preferably with no bullet connectors midway up the stator wires. Then the positive and negative straight from the R/R to the battery.
Has the R/R been relocated? And can you post a pic of it? Do you see any numbers similar to these on the R/R ... FH012AA or FH020AA?
post #5 of 5 (permalink) Old 07-09-2013, 11:57 AM Thread Starter
Thanx everyone, I will try these in hopes that I can find the problem, I will post a pic of the R/R .
rkama354 is offline
