Battery contact MELTED HELP!!!!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 39 (permalink) Old 06-26-2013, 05:18 PM Thread Starter
Ok, I am beyond pissed. I'm restoring an 86. I have not done any electrical work on the bike yet. I replaced the battery,Yuasa maintenance free battery. The bike worked with the old battery, as well as the new one. I go to fire up the bike and it wont turn over, so i remove the seat, and lo and behold the the F*&KING negative contact on the battery is melted off.
Please help me figure out why this has happened. I am about kill something...
SHAGGDOGG is offline
post #2 of 39 (permalink) Old 06-26-2013, 05:31 PM
Roach's Avatar
Is it possible that it wasn't tight, or loosened off a bit?
More resistance (bad connection) will cause more heat.
Street
1985 VN750 Acquired Feb, 2011 - 13,676km
Mods - Ear Shave, Pickup Coil Gap, Drilled Clutch Basket, Shift Tie Rod, Mosfet R/R, MF Battery, De-Goated (H-Pipe), MCCT, Heated Grips, Plexistar 2 Windshield
Dirt
2004 KTM SX 125 - 1979 Can-Am Qualifier 250 - 1971 Kawasaki F6
Video Tutorials - Engine Rebuild - Fork Seal Replacement - Grease Swing Arm Bearings - Carb Rebuild - Spline Lube - Refilling Rear Shocks - Grease Steering Bearings
Roach is offline
post #3 of 39 (permalink) Old 06-26-2013, 05:33 PM
Excess amp draw from the starter or cranking too long and overheating the wires. Those are two ways to do that.
post #4 of 39 (permalink) Old 06-26-2013, 05:41 PM Thread Starter
I cranked it maybe 5 sec. Piss me off, I'm out $100. My wife just told me "Forget trying to restore it, just go buy a new bike". I'ts now personal. I wish money grew on trees.
post #5 of 39 (permalink) Old 06-26-2013, 05:53 PM
I would attempt to come up with a jeri-rig of cable attachment.
Clean Starter Positive connection and all battery-frame grounds.
post #6 of 39 (permalink) Old 06-26-2013, 05:58 PM
I would put the old battery back in. Your ground wasn't tight
post #7 of 39 (permalink) Old 06-26-2013, 06:05 PM Thread Starter
I just put in the old battery, and no problem. FAAAAAAAAAK
post #8 of 39 (permalink) Old 06-26-2013, 06:24 PM
Having a similar problem. Bike was running fine on flooded battery... Put in new agm and as I screwed in the positive the negative wires started melting... No clue what just happened!
Hermis is offline
post #9 of 39 (permalink) Old 06-26-2013, 06:26 PM
Negative terminal melted off too
Hermis is offline
post #10 of 39 (permalink) Old 06-26-2013, 06:48 PM
I would check all ground connections. Maybe disconnect them, clean the contact area, and re-affix them.
