replacement headlight bulb, etc - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 02-11-2007, 09:11 AM Thread Starter
Drive less, ride more...
theauhawk's Avatar
In another thread I saw a discussion on system capacity, but to me the final answer wasn't very clear.
So....what extra capacity (watts) does the VN750 electrical/charging system have (if any), to power additional lighting beyond the stock configuration? If this amount fluctuates much, please explain...and so what would be a conservative figure?
Also: what is the brightest headlamp replacement bulb I can buy (but still with reasonable expected bulb life)--without exceeding the current 55/60 watt headlamp rating?
Thanks!....
theauhawk is offline
post #2 of 3 (permalink) Old 02-11-2007, 09:27 AM
Avid Rider
stevebtx12's Avatar
Send a message via Yahoo to stevebtx12
I'm running the PIAA H4 extreme white bulb in mine and just love it. Seems definitely twice as bright on high, these claim to provide 110W of light at the same 55W drain, so no extra added...
Steve in TX
'06 VN1600 Classic
V&H Bigshots
F&S windshield/lowers
Mustang seat/driver backrest
OEM saddle bags/Easy brackets
Phatt II risers
Cobra fatty highway bar/Kury Dually highway pegs
Cobra sissy bar/luggage rack
Iso Flame grips/throttle boss
VROC #22372
"Some days you're the windshield, some days you're the bug." (me)
stevebtx12 is offline
post #3 of 3 (permalink) Old 02-11-2007, 01:03 PM
Uber Member
you have about 70 watts extra max, with the stock stator. You could prolly go up to a 85 watt bulb, without too much of an issue except for the following... just keep in mind these bulbs burn hotter, and with that the filament is more fragile... this means since motorcycles are typically a rougher ride, the bulb my burn out even sooner. I also do recomend upgrading the wiring loom up to the headlight, as you may burn out the wiring from the heat. As for the reserve lighting unit, its a toss up if it can handle the extra load....
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
