HELP.... Need starter info! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 02-10-2007, 08:45 PM Thread Starter
Very cold here in Indiana. Tried to start the bike up and got nothing. Starter turned over once but still nothing. After a bit of trying sizzling sound and smoke coming from the front of starter. What do I have here?
Any help would be greatly appreciated.
Derek
dschwei is offline
post #2 of 14 (permalink) Old 02-10-2007, 09:06 PM
Cool
Make sure cable on the starter are tight.If they are and the starter is hot to the touch it will be time to replace starter.I hope it is a loose connection.Good Luck......................
Krawdad7 is offline
post #3 of 14 (permalink) Old 02-10-2007, 09:52 PM
Sky Rider's Avatar
You can rebuild the starter if it is the brushes or similar. If the armature is fried though, you'll have to replace the motor. Best bet is a used one from a slavage yard or ebay as a new one runs about $400 or so. Ridiculous in my opinion.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 14 (permalink) Old 02-11-2007, 07:41 PM Thread Starter
Post Loose!
I checked the starter connection and the actual post is loose from within the starter housing. My guess is that this is a bad thing. What do you all think?
Derek
dschwei is offline
post #5 of 14 (permalink) Old 02-14-2007, 08:13 PM
Cool
Yeah.I would look around for a place that rebuilds starters.400 bucks is a lot of money man..................
Krawdad7 is offline
post #6 of 14 (permalink) Old 02-14-2007, 08:44 PM
Crobins365's Avatar
Check eBay - there are starter rebuild kits available if your armature is still ok. I think they're around $70.
C
Crobins365 is offline
post #7 of 14 (permalink) Old 02-18-2007, 10:06 PM
Sky Rider's Avatar
If the post is loose, you will probably have to disassemble the starter and tighten it up from the inside. I am guessing here without having looked in the book but if it's loose, it won't allow a good electrical connection and that will cause your starter problems. You should check the maintenance manual first before tearing it all apart but it seems like a logical conclusion.
If tearing it apart is the way to fix it, make sure you inspect all the other parts while it's apart. Replace any that look or test questionable.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #8 of 14 (permalink) Old 02-18-2007, 10:18 PM
Uber Member
comming from someone who has rewound their own stator, you can do your starter too... just keep a few things in check.
pay attention to how the 'poles' of the armature are wound and connected. measure the gauge of the wire you have (you can use a set of gagued wire strippers to figure this out) Make sure the wire you buy is magnet wire, i suggest a polyester enameled one. and be very neat and slow. parts shouldnt cost you more then 30 bucks so long as the armature is ok...
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #9 of 14 (permalink) Old 02-18-2007, 10:19 PM
Sky Rider's Avatar
And you have tough fingers.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #10 of 14 (permalink) Old 02-19-2007, 12:28 PM Thread Starter
Fixed!
I purchased a used starter from the internet. I sent out a parts request to a salvage site and got reply's from over 30 different salvage yards with prices and guarantees. Took a $95 deal. received it 3 days later and installed it. The bike came to life with all of its glory. Lessons learned are that one must also plan on an oil change when replacing the starter. 4 quarts of oil will do a number on the garage floor.
thanks for all of your info. Good to know there is such a great and diverse group of riders out there on this network.
Derek
dschwei is offline
