Speedo Lights - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 02-09-2007, 06:32 PM Thread Starter
Speedo Lights
Im perplexed
The light on my speedomiter has burned out. Is there any way to replce the bulb?
The lights are off and im traviling in the dark!
LurchChaos is offline
post #2 of 16 (permalink) Old 02-09-2007, 07:09 PM
HAWK
Ccspinner's Avatar
Have you tried removing the cover to see if youcan get to the bulb from behind?
I believe you can, I had my tach appart and there was a bulb there.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #3 of 16 (permalink) Old 02-11-2007, 05:26 PM
Dan
Along this same line, my speedometer light is too dim and does not seem to distribute the light evenly over the entire speedometer. I can't read the odometer when I am driving at night because of this. The bike is a 2005 and has been that way since day-1. Anyone else have this situation?
Dan - Seattle
Dan is offline
post #4 of 16 (permalink) Old 02-11-2007, 09:48 PM
the speedo housing is sealed so no one can tamper with the odometer. i have heard either on this site or yahoo who have been able to work the housing apart to repair it, otherwise fabricate a LED lite outside the speedo to see it at nite
ride safe J
free wheel-e is offline
post #5 of 16 (permalink) Old 02-11-2007, 11:32 PM
From looking at the micro fiche on Ron Ayers, it would look like the bulb could be removable, but I don't know for sure.
Have ya tried to pull it out?
post #6 of 16 (permalink) Old 02-12-2007, 12:18 AM Thread Starter
scratching head
I looked at the Gauge it has a phillips screw at back side if the housing. The only issue i can see is having to pull the dash apart to remove the unit. Will try this next month after i send my Tank, fenders, and side covers out for paint.
post #7 of 16 (permalink) Old 02-12-2007, 02:00 AM
The rear cover should come off.
It's the trim ring around the front of it that isn't removable.
post #8 of 16 (permalink) Old 02-12-2007, 04:44 PM
Sky Rider's Avatar
The whole back end of the speedo and tach are accessable. The bulb is replaceable as well. It does require you to take the "dash" apart and remove the speedo from its bracket but once the back cover is off, all the wiring and the like is removable from there. Just make sure you remove the speedo cable as well. The mechanism inside the speedo is sealed and you can't get to it without some major surgery and it would be hard to put back together as it's nylon but all else is fair game.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 16 (permalink) Old 02-12-2007, 05:24 PM
Uber Member
Yep.... kinda a pain... i wonder how hard it would be to pull the nylon apart. i may see if i can find a beat up one on ebay to play around with... i would love to put in some nice red LED's
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #10 of 16 (permalink) Old 02-13-2007, 10:53 AM
fergy's Avatar
Hizzo, why would you want red leds shining in your eyes at night?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
