Taking off the rear light assembly? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-20-2013, 10:50 AM Thread Starter
Equinox's Avatar
The rear light assembly needs a real good cleaning and I don't think this bike has ever been washed... I can get the assembly off the fender, but, how does the wiring detach (and then re attach) from the turn signals? Is it at the crimp coming from under the seat, or is there a way to detach it from the base of the signal itself?
Thanks for the help,
Ox
Equinox is offline
post #2 of 5 (permalink) Old 06-20-2013, 12:26 PM
the connections are under the seat. they are solid wires from the bulb socket to that point.
You will just have to fish the wires out.
post #3 of 5 (permalink) Old 06-20-2013, 06:03 PM Thread Starter
Equinox's Avatar
Thumbs up Rear Light Assembly Wiring Diagram
Thanks to your help I was able to take the entire assembly off and clean easily a years worth of road and who knows what else off of the rear fender.
I took a picture and made this diagram for anyone else who might have had the same question I did.
Equinox is offline
post #4 of 5 (permalink) Old 06-20-2013, 11:41 PM
Ox
yes, they are snaked to up under the seat area.....detach electrically there, then pull/snake cable out towards the rear tail-light. I believe there are two points on the underside rear fender which you will be dealing with.
hope this helps
post #5 of 5 (permalink) Old 06-21-2013, 11:06 AM Thread Starter
Equinox's Avatar
I got the entire assembly off took pics and made a diagram of the electrics. Just waiting on moderator approval.
Equinox is offline
