Where's the thread about r/r relocation? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 21 (permalink) Old 02-01-2007, 05:23 PM Thread Starter
Hey all,
Okay so I searched the site, briefly, and couldn't find a link about the r/r relocation mod some of you have done. Let's just say the new thread from the new KAW rep member got me thinking I might want to do it. It would be a good mod due to the nice, errr I mean blazing hot summers we have around here!?
Thanks for the help
JohnBoy750 is offline
post #2 of 21 (permalink) Old 02-01-2007, 05:46 PM
93VN750's Avatar
John -
There are more, but here's a start.
http://www.breyn.com/vn750/relorr.htm
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 21 (permalink) Old 02-01-2007, 06:00 PM
Crobins365's Avatar
Here's a link to Fergy's post and pics, too.
http://pages.tstar.net/~fergy/writeu..._relocate.html
Definitely a must-do!!
C
Crobins365 is offline
post #4 of 21 (permalink) Old 02-01-2007, 06:20 PM Thread Starter
Wow, I didin't remember it being that easy to do!
Doesn't the battery box just pop out after loosening a few bolts or not?
post #5 of 21 (permalink) Old 02-01-2007, 06:29 PM
fergy's Avatar
I had to replace my r/r on my cop bike and couldn't get to the bolt heads because of having sasquatch hands, so I drilled out the bolts from the top of the battery box. It made it easy to put new ones in and tighten up from the top. So when I relocated my r/r on the 750, I didn't even think twice about it. I just drilled them out. I just couldn't see removing any more than I had to for the job. I know several have taken the battery box loose to do the job, but I say why? You're not going to put anything back there. Save yourself some time and drill em. Use a magnet to pick up the shavings. It's easy.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #6 of 21 (permalink) Old 02-02-2007, 08:58 AM
93VN750's Avatar
Yes, four bolts and a connector or two and its movable. A bit more work to remove it but you don't have to. Just tilt it to get to the bottom and the r/r connector.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #7 of 21 (permalink) Old 02-03-2007, 09:35 AM Thread Starter
Aahhh thanks for the suggestions hopefully in the very near future my r/r will have a new happy home on the left side!!!
"Oooooh feel that wind, " said the newly re-located r/r.
post #8 of 21 (permalink) Old 02-03-2007, 11:44 PM
Benjammin'
BSkaggs513's Avatar
I am also going to relocate the R/R this spring. As long as I was working on the unit, I was planning on pulling the electrical connection and coating it with dielectric grease. I believe I read where some folks recommend that. Is it worth doing?
Ben-
SW Ohio
'02 VN750
Pipes drilled
Spline lubed
AGM batteried
Iridium equipped
LED tail lighted
8000-ish miled
Soon to be MCCTed
Lovin Life.
BSkaggs513 is offline
post #9 of 21 (permalink) Old 02-04-2007, 12:24 AM
HAWK
Ccspinner's Avatar
Bulldog makes a nice Bracket to move the R/R
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #10 of 21 (permalink) Old 02-04-2007, 09:24 AM
Crobins365's Avatar
Definitely worth it. The grease protects the leads from corrosion, and also facilitate electrical contact.While you're in there, you might as well pack the other leads coming off the battery box. It's a good habit to get into. I think I bought a can with an applicator thing for a few dollars at Napa or Antietam Auto. Cheap, but well worth it.
C
