Question about accessory connection - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 01-21-2007, 10:50 AM Thread Starter
Avid Rider
stevebtx12's Avatar
Send a message via Yahoo to stevebtx12
I finally got my Kuryakyn LED battery gauge in, and was wondering if anyone could tell me if the spare accessory connection up by the headlight would be a good place to connect this? And, if anyone knows if this connection is only powered on when the key is on, or only when the engine is running? Thanks for any help here.
Steve in TX
'06 VN1600 Classic
V&H Bigshots
F&S windshield/lowers
Mustang seat/driver backrest
OEM saddle bags/Easy brackets
Phatt II risers
Cobra fatty highway bar/Kury Dually highway pegs
Cobra sissy bar/luggage rack
Iso Flame grips/throttle boss
VROC #22372
"Some days you're the windshield, some days you're the bug." (me)
stevebtx12 is offline
post #2 of 6 (permalink) Old 01-21-2007, 02:50 PM
Uber Member
IIRC that is in an always on. may be wrong with that.... I recomend the battery meter connected directly to the battery terminals though. you can do this with a small automotive relay with the signal side run off the igition switch, headlight or put in your own switch so you can check it without starting it. i think there was a .25 volt drop from battery to the headlight housing... may not seem much but at idle every volt counts.....
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #3 of 6 (permalink) Old 01-25-2007, 02:12 PM
darrelc5's Avatar
I just installed the single-LED Heads-Up battery monitor/gauge and opted to use the dash lighting circuit to power it. This is the same circuit which powers the front parking lights. I measured about ~0.35V drop between the battery and the connector where the fuel gauge lights plug in behind the headlight. What the heck, the gauge will still do it's job...if it indicates low, then I have a charging problem.
To mount the voltage monitor circuit box, I zip-tied it to the frame under the gas tank near the thermostat and routed the wires forward to the back of the headlight bucket. I cut the wires there and reconnected them with a 6-pin Molex connector and mounted the indicator LED through the instrument panel next to the ignition key. This lets me remove the gauge cluster without removing the battery monitor circuit.
By the way, I tested the accessory plug-in inside the headlight bucket, and it's always on.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #4 of 6 (permalink) Old 01-25-2007, 02:18 PM
93VN750's Avatar
I got a LCD voltmeter/clock/thermometer mounted on top of the triple forks.
The meter leads go directly to the battery. The power lead for the gauge (switched with key) is connected to the hot lead for the rear coil. Keeps all the connections right in the battery area.
Been getting 13.1-13.3 at idle and 14+ above 2500rpm since putting in my Rick's stator and R/R.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 6 (permalink) Old 01-25-2007, 02:30 PM
darrelc5's Avatar
Sounds good! I suppose you routed all this when the tank was off while replacing your stator.
I just got my engine back in after replacing the stator (second time!). I used the Rick's product after hearing your description and talking to Rick. I need to test it better, but I think I'm getting about the same voltage. Unfortunately, I have been focusing more on getting it to run correctly. I'll post a question in the other forum about that.
Darrel
-Corbin Seat
-V-Force Windshield
-Brakelight Flasher
-MF Battery
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #6 of 6 (permalink) Old 01-25-2007, 03:57 PM
93VN750's Avatar
Yes, while the tank was off, but don't see why it couldn't be done with the tank on. Just fish the leads along side the factory harness.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
