Park light problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 01-02-2007, 09:05 AM Thread Starter
OzKaw's Avatar
Park light problem
I charged up an old battery and put it in the bike to see if all my new light connections, new indicators etc..., all worked ok. Everything seemed good. Indicators blinking, headlight, tail and brake light all worked well.
The problem arose when I tried to turn off the headlight, or more specifically the park light. The main headlight turns off fine, but the small park bulb wonít switch off. Switching it off at the switch block has no effect, and I can turn the key to any spot on the ignition switch and it just stays on. Itís only when I disconnect the battery that it turns off.
Iím guessing that the problem lies with the ignition switch, which feels pretty worn.
Would this be correct, or should I be looking somewhere else for a fault?
Alternately, should I just disconnect the park light? Iíd much rather just do that than replace the entire ignition switch, or could just disconnecting the bulb cause other problems?
Rebuild completed April '07
Pics here
2005 Z750
107 RWHP
Pic here
OzKaw is offline
post #2 of 11 (permalink) Old 01-02-2007, 11:51 AM
Spriddle's Avatar
Thats a tough one,wish i could help,but without a schematic i would guess that
the only switch would be the ignition,good luck.
Spriddle is offline
post #3 of 11 (permalink) Old 01-02-2007, 12:11 PM
Geek
rnewell's Avatar
If it is the switch I would replce it. You might find other problems down the road. (No pun intended)
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #4 of 11 (permalink) Old 01-02-2007, 02:37 PM
Hmm, when you say 'park light', do you mean the rear, red tail light or the front orange ones? (or some aftermarket one, because it kinda sounds like the way you describe it, that it's in the headlight bucket?)
post #5 of 11 (permalink) Old 01-02-2007, 06:00 PM
Rubline's Avatar
Sounds like the switch to me.
Rubline is offline
post #6 of 11 (permalink) Old 01-02-2007, 07:55 PM Thread Starter
OzKaw's Avatar
The bulb that I am referring to is the small one inside the headlight shell.
(see pics)
I couldn't find any reference to this light in the manual, so perhaps it's
only a feature of the models imported to Australia.
ID:	208   Click image for larger version
Pics here
2005 Z750
107 RWHP
Pic here
OzKaw is offline
post #7 of 11 (permalink) Old 01-02-2007, 09:39 PM
HAWK
Ccspinner's Avatar
Must be a Ausy thing. Not in the states, at least not on my 01
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #8 of 11 (permalink) Old 01-02-2007, 10:30 PM
Uber Member
ahh ok, its his running light. In non US models, there is a running light vs running the headlight at all times... sounds like the ignition switch. check it first, and let us know.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #9 of 11 (permalink) Old 01-03-2007, 05:51 AM
Ah ha, it is IN the headlight.
Hope ya can figure it out. If not, ya could probably add a relay to it.
post #10 of 11 (permalink) Old 01-03-2007, 06:11 AM Thread Starter
OzKaw's Avatar
Well I discovered that the problem is not with the ignition switch.
I removed the ignition to clean the connections, and discovered that the light stays on, even when the ignition switch is totally removed!!
I think Iíll just leave that bulb unplugged and see how it goes.
Cheers.
Pics here
2005 Z750
107 RWHP
Pic here
OzKaw is offline
