died on me during a benefit ride - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 52 (permalink) Old 05-25-2013, 02:42 PM Thread Starter
Glenn C.
gcextreme's Avatar
Was road guarding for a benefit ride and came to my stop and the bike died and wont start...it just clicks..
The battery was fully charged a few days ago.
Did the stator mod last spring with a new TPE stator and r/r (which has been relocated)
Im hoping its just the battery, and not the charging system.
So far since getting the bike out of storage ive only put on about 50 miles.
Today i rode it to town about 20 miles and around town and then met up for the ride..and the bike was riding fine...made it for like 25 miles of the ride before it died at my stop where i was to stop traffic.
The chase vehicle had a trailer and loaded me up and took me back to town.
Any ideas or suggestions?
Glenn C
Alexandria, MN
My VN750 Page
VN750 Stator Plates and Products
2001 Kawasaki Vulcan VN750
1986 Kawasaki Vulcan VN750 (being restored)
1986 Kawasaki 454LTD (being restored)
1985 Kawasaki 454LTD (being restored)
gcextreme is offline
post #2 of 52 (permalink) Old 05-25-2013, 03:29 PM Thread Starter
Glenn C.
gcextreme's Avatar
Jump started it and while running it with a tester it reads like 9.65
Glenn C
Alexandria, MN
My VN750 Page
post #3 of 52 (permalink) Old 05-25-2013, 03:34 PM
Check your Stator connections....
post #4 of 52 (permalink) Old 05-25-2013, 03:38 PM Thread Starter
Glenn C.
gcextreme's Avatar
At the stator orthe r/r?
Glenn C
Alexandria, MN
My VN750 Page
post #5 of 52 (permalink) Old 05-25-2013, 03:56 PM
The three wires from the stator to the r/r ...some riders cut off the butt connectors, then solder those connections. Check/Clean the contacts on the R/R connector.
post #6 of 52 (permalink) Old 05-25-2013, 04:02 PM
Ceal's Avatar
Or better yet, run the 3 stator wires straight to the RR with new wires instead of the old wiring, and run the regulator outputs directly to the battery with new wiring, bypassing the old wiring harness. If there was some short or crimped wire anywhere in there, you will have bypassed it if you do this; plus, it gives you better power, and it helps if you use a heavier gauge of cable than the original as well.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #7 of 52 (permalink) Old 05-25-2013, 04:35 PM Thread Starter
Glenn C.
gcextreme's Avatar
thanks right now got my truck and trailer I'm going to go pick it up I will have to look into it tomorrow I got too much going on tonight but I did pick up some oil and filter so I can drain the oil out and pull the stator and check it
Glenn C
Alexandria, MN
My VN750 Page
post #8 of 52 (permalink) Old 05-25-2013, 06:48 PM
Ceal's Avatar
You might avoid pulling it if you check things with a multimeter first... it could be something as simple as a loose wire.
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #9 of 52 (permalink) Old 05-25-2013, 09:49 PM
Agreed with Ceal...a TPE stator rarely quits...and since it was so sudden instead of gradual, I suspect a connection or the RR itself...doubt much its the stator...
post #10 of 52 (permalink) Old 05-26-2013, 12:18 AM Thread Starter
Glenn C.
gcextreme's Avatar
thanks... i will go thru it and check out stuff tomorrow.
i know theres a thread with info on checking the ohms and stuff for the stator and r/r to see what they are at and supposed to be at...but i cant find it...
anyone have a link to that thread or info/diagrams??
I swore it was like a check list of stuff to check and what they should read at.....
I got the bike trailered home, its in the garage..
thanks guys...
Glenn C
Alexandria, MN
My VN750 Page
