need a new bulb - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-25-2013, 01:21 PM Thread Starter
oriontheblacksmith's Avatar
Question need a new bulb
i need to replace the bulb in my turn signal and i dont know what type to get, anybody know?
oriontheblacksmith is offline
post #2 of 8 (permalink) Old 05-25-2013, 02:01 PM
Do you have the bike manual? It will say in there what the bulbs are.
Fronts are 32/3CP
rears are 32CP
post #3 of 8 (permalink) Old 05-25-2013, 05:18 PM
stock fronts are 1157(dual filament) bulb...rear ones are 1147(single filament)
or you could replace the bulbs with LED inserts....check my signature for info.
post #4 of 8 (permalink) Old 05-25-2013, 06:56 PM
JM2001's Avatar
Rears are 1156 single filament
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 8 (permalink) Old 05-25-2013, 07:02 PM
Straight from the repair manual:
Front: 92069-060 32/3CP 12V Bulb
Rear: 92069-055 32CP 12V Bulb
post #6 of 8 (permalink) Old 05-26-2013, 07:59 AM
you are correct sir!
My fault for not double checking and going from memory. I apologize for giving incorrect information!
post #7 of 8 (permalink) Old 05-26-2013, 08:09 AM
JM2001's Avatar
No problem Kc. We've all done it unintentionally
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #8 of 8 (permalink) Old 05-26-2013, 03:14 PM
The 8 digit numer in red is Ma Kaw's part number.
The blue highlighted numbers are the specs, 32 and 3 candle power respectively
1156 and 1157 are universal numbers asigned to specific bulbs made by any manufacturer and recognized by any automotive supplier.
Now just a heads up here, the bulbs in my front and rear signals are #1034 and #1073 respectively. So if you have these differently numbered bulbs and cannot locate them at your local parts store, the bases appear to be the same as 1157 and 1156 bulbs, and I am sure they are interhangeable. smiley_th
BTW, the specs for the bulbs in the Clymer manual are not given in cp (candle power) but are given as 8 watts for the front running lights, and 23 watts for both front and rear turn signals.
