Let's Invent Something - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 29 (permalink) Old 05-24-2013, 09:31 AM Thread Starter
Lightbulb Let's Invent Something
Looking for different ideas on how to clamp these wires in place on top of the transmission.
I'm relocating the stator leads and pickup coil wiring to the top of the trans. The wires get twisted and tortured down between the stator cover and bevel gear and should run cooler if routed over the top.
There's an empty loop or lifting eye toward the top/middle of the trans and I want to come up with something to hold the wires at that loop.
I know I could simply fold up a piece of metal and drill a bolt hole, or just zip-tie it all, but I thought we could brainstorm it and maybe come up with a manufactured piece that would work better and possibly suspend the wires an inch or so above the trans case.
I'll edit a pic or two into this post later when I have time.
post #2 of 29 (permalink) Old 05-24-2013, 09:52 AM
I'd just glue them down with a silicone adhesive. If you wanted them to stay off the cases you could just glue a piece of some thick wall tubing down first and run the wires through it.
post #3 of 29 (permalink) Old 05-24-2013, 10:07 AM Thread Starter
Thumbs up
Not a bad idea, especially the insulating part, but that loop just seems so dang handy to bolt something onto. And bolting is more secure.
Originally, I thought I'd need to keep the wires toward the outside, and thought about using 6" long all-thread to put the hanger out where I want it, then use the original clamp on a top bolt of the bevel gear case, but I have plenty of wire to reach that loop and it doesn't add much length to put them in the middle.
post #4 of 29 (permalink) Old 05-24-2013, 10:13 AM
HardRock's Avatar
Machine a scaled down riser to bolt there and run the wires through where the handle bars would go on a full size riser.
HardRock is offline
post #5 of 29 (permalink) Old 05-24-2013, 10:24 AM Thread Starter
Aha, see, I just needed a kickstart.
Good idea, and got me thinking about an eyebolt.
The loop on the trans case is approx. 3/8" diameter, maybe 5/16", easy to find on your bike.
Gotta head to the mountains for my farm chores, be back tonight, but keep those ideers comin'!
post #6 of 29 (permalink) Old 05-24-2013, 11:45 AM
Just curious here......are we talking about the 3 yellow stator wires?
How long are you planning on making the wire run?
Heavier wire is ok, but we are talking AC signal here....longer wires will cause losses in the signal..especially since they are single wires and no shielding.
Consider that a (grounded) ferrous metal loop that a wire passes through also acts like a suppressor and might also deteriorate the signals....and could become magnetized as well.
just something to think about.....
post #7 of 29 (permalink) Old 05-24-2013, 12:41 PM
I agree 100 % ...and are true facts above.
Deterioration should not be significant enough to notice or cause problems.
Magnetization... maybe ever so slightly, but so what ? No harm.
WilliamTech +1
post #8 of 29 (permalink) Old 05-24-2013, 12:55 PM
HardRock's Avatar
If a metal loop is a concern machine the thing out of a high temp nylon or a similiar material.
HardRock is offline
post #9 of 29 (permalink) Old 05-25-2013, 10:53 AM Thread Starter
Question
I know I could get one done in Teflon.
Not sure the wires would really be any longer. R/R is relocated to the left side cover, and instead of down/around the bevel gear case, it's going straight out of the stator cover, over the top to the hanger, then straight to the R/R.
Not sure I understand "AC signal", I normally associate shielded wire with audio/video. The current should make the trip, assuming my choice of wire gauge is ok. (posted a question about that) I do understand that long runs will cause losses in amperage, but no amount of shielding stops that, only heavier gauge wire, right?
So if I do rule out a metal hanger, maybe find the right cable clamp that can attach to the loop on the case, or to a bolt.
Aww hell, maybe I should just insulate and zip-tie the bundles to the loop?
post #10 of 29 (permalink) Old 05-25-2013, 11:11 AM Thread Starter
Actually, I know the wires will be shorter by running them over the top.
I made the R/R leads to connect to the original stator leads, now with rerouting the wires, the R/R leads would reach the outside of the stator cover, instead of just making it to the original leads like it did with the old routing.
