cut and gut - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 11-28-2006, 07:23 PM Thread Starter
cut and gut
Building old school bobber. Anyone know just how much of the elec. system i can cut out and still run. Looking for bare min. thanks
93farley is offline
post #2 of 4 (permalink) Old 11-28-2006, 07:56 PM
Our E-systems are only half there when they're new, I would'nt mess with it if I didn't have to.
Woody is offline
post #3 of 4 (permalink) Old 11-28-2006, 08:41 PM
Search Goddess
Dianna's Avatar
State laws will dictate bare minimum. You need a headlight in all states. Some states don't require turnsignals.
Instrument clusters you don't need if you are going for the clean look. I'd stick with some sort of speedometer though just to avoid tickets though.
If you are eliminating the fuel gauge (with the insturment panel) then of course you will want to know the range of your bike so a speedo/trip in handy.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #4 of 4 (permalink) Old 12-11-2006, 02:12 PM
EDALBRIS's Avatar
you can remove the entire harness leave the stator pluged into r/r and r/r onto battery + earth, leave i.c. pickups conected to ic, now take a look at the wiring diagram in the manual, conect the two coil wires (front and rear) from the ic box to the + terninal on there respective coil and a ground wire from - terminal of coil to the frame, and a +feed with a switch to the ign.terminal and retarder terminal (these can be linked) on the ic box, all you need now are wires to triger the starter solinoid and she will start.
now just select what equipment you want to keep on the bike and run descreet wires to each using the wiring diagam in the manual.
BEST OF HEALTH AND HAPPYNESS
EDALBRIS
1952 NORTON (MODEL ONE) 'BIG 4'
1955 NORTON DOMINATOR 88/99 CAFE RACER
1981 KAWASAKI Z1000ST SHAFT
1988 KAWASAKI VN750 (UK) HARDTAIL + 5"
1988 KAWASAKI VULCAN 750 (US)
ALL TIME WISHLIST BIKES
1939 BROUGH SUPERIOR SS100 GRAND ALPINE SPORT
ANY 1940ish NORTON WITH CS1 ENGINE
A RIDE ON A NORTON NEMISIS 'A'
NEVER HAD A CAR LICENCE AND HOPFULLY NEVER WILL
EDALBRIS is offline
