Stator and parts on order..... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 11-20-2006, 02:27 PM Thread Starter
93VN750's Avatar
Should arrive by early next week. Will start the disassembly in the meantime.
The fun begins......
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 8 (permalink) Old 11-20-2006, 03:16 PM
Best of luck to ya Jon.
And remember, don't put any of yours or any helpers body parts under the motor when you're ready to move it !!!
post #3 of 8 (permalink) Old 11-20-2006, 03:22 PM Thread Starter
93VN750's Avatar
Hey Artybolt, make sure you read this!!!
I'm a firm believer in measure twice, cut once, and all those related lines of thought.
I'll keep you posted on progress.
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #4 of 8 (permalink) Old 11-20-2006, 04:11 PM
Jon
Just let me know I will be there for you.
artybolt is offline
post #5 of 8 (permalink) Old 11-20-2006, 05:12 PM
Search Goddess
Dianna's Avatar
One little note..
If you are starting disassembly and the bike will be out and apart for a bit.. slip a plastic bag over the manifold and bevel gear areas etc so you don't end up with any foreign critters looking for a new home!
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 8 (permalink) Old 11-20-2006, 08:27 PM Thread Starter
93VN750's Avatar
Originally Posted by Dianna
One little note..
If they get into the garage, I've got bigger problems!
Thanks for the advise, snakes and fruit rats get into everything here in Florida, except my garage (so far).
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #7 of 8 (permalink) Old 11-20-2006, 10:48 PM
Search Goddess
Dianna's Avatar
*L* It's not just big critters. I'm thinking, spiders, beetles, flies. little mice and.. dust and dirt. Dust and dirt the most likely.
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #8 of 8 (permalink) Old 11-20-2006, 11:12 PM
Sky Rider's Avatar
Cockroaches are a pain. I thought I had fried my stator because during an oil change it appeared as though the epoxy covering the stator was in the screen. I pulled the stator cover to check and everything looked good and it turned out to be a very large cockroach carapace and associated parts. Blech.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
