My 1st Stator check out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 22 (permalink) Old 05-12-2013, 07:58 PM Thread Starter
OK, so last year one of my friends at my previous job said his stator went bad on his 86 VN750. He didn't get a chance to bring it over last year so finally he was able to drop it off today. Went over sticky on testing and is sure looks bad to me.
Checking the voltage at the battery at idle I had 11.8 and when rev'd up to 4,000 I was getting around 12.1, so on to the stator test.
With meter set to 200 Ohms I'm getting between 7.6 & 7.7 across all 3 wires to the engine case.
With the engine running & meter set at VAC 200 I'm getting mid to low 20's between each lead and it should be 40 to 70 VAC.
So looks like I'm going with the engine pull route, since I've done it before and then get TPE to do it for him. Hoping I'll get him on the road again before the 1st week of June.
So what's the easiest way to pull the R/R? I was thinking of pulling the battery box, but if I pull the engine I have to remove the exhaust anyway so that might be easier.
post #2 of 22 (permalink) Old 05-12-2013, 08:01 PM
What I did was unbolted the battery box and unbolted and moved the JB. I was able to tilt the bottom of the box towards me where I could get a 10mm wrench in there. I tried to get at it from underneath, but the swing arm was too close to get a wrench to the bolt.
post #3 of 22 (permalink) Old 05-12-2013, 08:45 PM
bamafrankie
bamafrankie's Avatar
I JUST REPLACED MY R/R AND I RELOCATED MINE IN THE PROCESS. I JUST UNPLUGGED MINE AND INSTALLED NEW R/R IN NEW LOCATION AND DRILLED OUT THE BOLTS TO THE OLD ONE
I JUST HAD CHARGING TROUBLES AND I HAD MID/LOW 20vac AL LOW RPM BECAUSE I COULDN'T GET IT TO REV HIGHER REPLACED BATTERY NOW ITS DOING FINE I'M GETTING 13plus VOLTS AT IDLE AND OVER 14 AT 3K. JUST FOOD FOR THOUGHT
bamafrankie is offline
post #4 of 22 (permalink) Old 05-12-2013, 10:06 PM
When I had to replace mine I just relocated it and didn't even bother to take the old one out. Even if you put it back where it came from drilling the bolts out seems easy enough and you can put new uncorroded bolts back in easier,
post #5 of 22 (permalink) Old 05-12-2013, 10:22 PM
Okiebezer's Avatar
I drilled mine out from top and moved it over by the left side passenger foot peg. Not too bad, didn't take too long.
I used part of a 2" x 1/8" aluminum flat stock piece that I had left over from making coasters. Also used a conduit bracket from electrical dept at HD, I think was about a 1" or 3/4" piece. Some clear rubber tubing I had slipped over the bracket portion and secured to the frame. Very sturdy.
Okiebezer is offline
post #6 of 22 (permalink) Old 05-13-2013, 02:45 PM
When i relocated mine, I just unbolted the battery box and tilted it so I could get a wrench on the R/R.
It wasn't that hard to get to honestly.
post #7 of 22 (permalink) Old 05-13-2013, 04:16 PM Thread Starter
So does the plug come right out of the R/R? I was trying to pull the plug off last night and it seems to hang up. Is there a clip holding it? I plan on putting a new one on and just might leave the old one there.
post #8 of 22 (permalink) Old 05-13-2013, 04:33 PM
Captive New Yorker....
peterherrm's Avatar
You've got to squeeze the tab to get the plug out. My bike is a 94 and I think I had the original R/R in there, so the plug was really stuck in there. Took a while to get it out.
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #9 of 22 (permalink) Old 05-14-2013, 09:02 AM
parts
are you going to buy this?
ttp://www.ebay.com/itm/STATOR-REGULATOR-RECTIFIER-KAWASAKI-VN750-VULCAN-750-1986-2006-MOTORCYCLE-/280988744272?item=280988744272&vxp=mtr
saw that in the parts page here. I need it . Should I prefer Electrosport instead of this ? This is a good price. R/R alone at any Kawa distributor $170. Anyone know about Caltric quality?
GENERA1 is offline
post #10 of 22 (permalink) Old 05-14-2013, 09:31 AM
JM2001's Avatar
I would go with this Mosfet one. A little more but way better.
http://www.roadstercycle.com/
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
