spark plug wire arc - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 11-07-2006, 09:06 PM Thread Starter
Unhappy spark plug wire arc
Hope someone can help!!!
My VN750 left front spark plug wire is arcing through the boot where the wire screws on to the plastic extension that goes into the head.
I changed the plugs I thought I had a bad plug, this did not correct the problem. I also unscrewed the wire from the spark plug extension and cleaned that still have the problem please help
K-VN750 is offline
post #2 of 2 (permalink) Old 11-07-2006, 10:53 PM
Search Goddess
Dianna's Avatar
Usually it's the right side front plug that develops an arcing problem. The wire would arc against one of the fins on the engine. This is usually solved by simply rerouting the wire.
With the left front plug though I'd check the boot for cracks and check the insulation on the wire. You could try wrapping the boot and the wire leading into the boot with some electrical tape and see if it eliminates the arc. If it does, replace the wire and boot
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
