Remoute start engine dream - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 11-06-2006, 11:00 AM Thread Starter
Taras_s's Avatar
HI,all
I want to do remoute start engine by pressing button on signalization pager, need elektrical schem, or may be someone does someting like that.
Signalization will install in any case (It's necessary in our Country- Ukraine).
What kind of neutral sensor, simple switch?
Taras_s is offline
post #2 of 15 (permalink) Old 11-06-2006, 11:54 AM
tankist's Avatar
Send a message via Skype™ to tankist
neutral sensor is easy - you have neutral indication light right on yor dashboard. however take into ac**** that starting our bikes cold 99.99% of the time involves choke lever manipulation and giving them a bit of throttle too sometimes. IMO fuel injected vehicles are better candidates for remote start.
http://agrasyuk.googlepages.com/home
Anton Grasyuk
Wheeling, IL
tankist is offline
post #3 of 15 (permalink) Old 11-06-2006, 03:43 PM
HAWK
Ccspinner's Avatar
I used to instal remote starts on cars and stucks, YOu have to have EFI or won't work. Also if you leave in gear bike will jump off the stand and that will be bad.
I would not recomend a remote start on a bike ever.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #4 of 15 (permalink) Old 11-06-2006, 05:14 PM
Uber Member
the bike will have to be EFI. give me a year or 2 as i am working on an efi unit for the bike. other then that you can just rig it up like you would on a car, except the neutral switch will be run off the neutral light. that will keep it from starting while in gear.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 15 (permalink) Old 11-07-2006, 04:05 AM Thread Starter
Taras_s's Avatar
That right, neutral sensor will be involved to keep bike from starting while in gear.
As for choke lever manipulation, I think it's not so problem, couse there is elertrical switch.
Taras_s is offline
post #6 of 15 (permalink) Old 11-07-2006, 08:14 AM
Once Banned
cegodsey's Avatar
Just remember to turn the choke on after you stop the bike at night. The only problem is that you know how the rpms go way up after you start it with the choke. If there was a way to automatically adjust the choke as the engine warms...
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #7 of 15 (permalink) Old 11-07-2006, 03:11 PM
tankist's Avatar
Taras, our chocke is Manual lever connected with cable to the carb choke module (read somwhere on our bike it is enricher actually rather then choke - correct me here if wrong) . no electrical switches involved there.
start procedure that i go through:
set choke lever to 1/2 engaged, crank starter until engine picks up (usually 1.5 cranks or so, if it doesnt i give a bit of throttle to), and set the chocke to almost fully engage immidiatley. the RPM reaching 2000 and in matter of seconds begins to climb. i gradually disengage choke to keep it on 2000RPM after about 2 minutes the engine will hold itself on idle without sputtering with choke disengaged.
what this means is - the way i see it you will need strong servo motor with higher Amperage controller circuit (dunno about others but my choke lever is somewhat stiff ) to acutate the choke lever depending on feedback recieved from RPM sensor cirquit (which also needs planning and design). it is not good to let the engine race so leaving the lever engaged in the evening is not a solution i would use.
besides why do you need remote start anyways? it only takes 1-2 minutes tops to warm up from 45F or 8C degrees outside temp, and it's not like you going to have warmed up interioir of the car anyways.
Anton Grasyuk
Wheeling, IL
tankist is offline
post #8 of 15 (permalink) Old 11-07-2006, 03:56 PM
fergy's Avatar
I'm curious as to why you would want your bike to remote start?
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #9 of 15 (permalink) Old 11-07-2006, 07:18 PM
Uber Member
i wouldnt mind remote start.... also would like hydrolics that would lay the bike on its frame when i turn it off..... that would be cool :P..... can i also get a talking wrist watch, and a cool sweeping red light on the front fender? then i can call my bike 'kit'
regardless, efi will be needed no matter how you look at it...
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #10 of 15 (permalink) Old 11-07-2006, 10:07 PM
Once Banned
cegodsey's Avatar
I built a sweeping red light for the front of my car. Did it in 1984. I've got one in my room right now, using jumbo super bright LEDs glued into flashlight reflectors. Outstandingly bright. For my first build, it cost $150 in parts. My second cost $80 in parts, and my third (if I ever finish it) will have cost me $10 in parts.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
