Rectifier Plug - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 05-07-2013, 10:30 PM Thread Starter
mnich797's Avatar
Rectifier Plug
Looking for a rectifier plug replacement anyone know of any aftermarket kits available?
1993 VN750
Purchased 12-26-2012
DPR7EIX-9 Iridium Spark Plugs
De-Goated
Rear Turn Signals Relocated
Splines Lubed
Mac 2 into 2 Staggered Exhaust
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
post #2 of 5 (permalink) Old 05-08-2013, 06:54 AM
I've never seen an aftermarket but you could keep an eye on eBay for a cheep wiring harness.
You could always connect it without a plug. Just crimp & solder new spade connectors.
Use heat shrink on the ends to cover the spades & your good to go.
Not a factory fix, but a fix.
What happened to yours?
post #3 of 5 (permalink) Old 05-08-2013, 08:42 AM Thread Starter
mnich797's Avatar
Heavily corroded with the white wire rotted off.
1993 VN750
De-Goated
Splines Lubed
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
post #4 of 5 (permalink) Old 05-08-2013, 10:35 AM
darrelc5's Avatar
This may be what you need. I have used the "6P250 CNA Tang-Less Set" before, shown about halfway down on this page. Also, it pays to order spare socket inserts with it.
http://www.easternbeaver.com/Main/El...cna250-tl.html
It pays to use a good barrel crimper, but you can use needle nose pliers; just don't compress too hard or you will "banana" the insert. If you have concerns about corrosion, hit the rear of the socket with solder once it's crimped.
Let us know if it works for you.
Darrel
'03 Vulcan 750 (90k miles)
-Corbin Seat
-V-Force Windshield
-LeatherLyke Touring Bags
-Chrome Luggage Rack
-Headlight Modulator
-Brakelight Flasher
-MF Battery
-Heads-Up Voltage Monitor
-Replaced Stator (9,000 and 16,000 mi.)
-Oil-cooled Stator Mod (photos)
-Replaced and Relocated R/R
-Greased rear splines
-Fused Stator (photos)
-Metzeler ME880 Marathon 170/80-15 (Rear), 110/90-19 (Front)
-TOC MCCTs installed
-Headlight Relays
SOLD - 2013
darrelc5 is offline
post #5 of 5 (permalink) Old 05-08-2013, 10:10 PM Thread Starter
mnich797's Avatar
Thanks!!
1993 VN750
De-Goated
Splines Lubed
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
