License Plate Bulb Replacement??? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 10-31-2006, 08:11 PM Thread Starter
93VN750's Avatar
Anyone know if a Sylvania 97 bulb is a cross to the license plate bulb? Can't find ratings for it anywhere.
Thanks,
Jon
93VN750 is offline
post #2 of 10 (permalink) Old 11-01-2006, 04:47 AM
All I was able to find so far is that the stock bulb is 5w.
post #3 of 10 (permalink) Old 11-01-2006, 05:38 AM
Once Banned
cegodsey's Avatar
If Dianna doesn't know, then the next best thing would be to yank it and take it into an auto parts place.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #4 of 10 (permalink) Old 11-01-2006, 08:01 AM Thread Starter
93VN750's Avatar
I did, they scratched their head, and borrowed my magnifying glass. Seems to be the same brightness and is for license plates, but probably automotive.
If I get a chance, I'll measure the current into it and find out the wattage and see if it makes sense.
Jon
93VN750 is offline
post #5 of 10 (permalink) Old 11-01-2006, 09:14 AM
Search Goddess
Dianna's Avatar
Ron Ayers lists it as a BULB,12V 5W and/or BULB,12V 4CP
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #6 of 10 (permalink) Old 11-01-2006, 09:16 AM Thread Starter
93VN750's Avatar
I found the 5w and 4 candle power ratings for the replacment, can't find Sylvania's ratings for their 97 bulb anywhere.
Jon
93VN750 is offline
post #7 of 10 (permalink) Old 11-01-2006, 09:21 AM
Search Goddess
Dianna's Avatar
Found it.. looks like a 13.5V bulb
97MINI .69A 13.5V G-6 SINGLE CONTACT BAYONETE BASE
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #8 of 10 (permalink) Old 11-01-2006, 10:55 AM
Uber Member
when i do get to my fender change, i plan to install LED lighting to light the plate... should drain less then 1.5 watts.....seems minimal, but ever watt counts!
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #9 of 10 (permalink) Old 11-01-2006, 11:05 AM
Search Goddess
Dianna's Avatar
One comment on the LED replacement..
You will have to make sure the LED shines down or refects back to the license plate. Most LEDs are designed to project out.
You can use them of course but you will either have to change the placement of the socket or add reflective material to the cowl.
Dianna
Conway, AR
Patriot Guard Rider
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #10 of 10 (permalink) Old 11-01-2006, 11:09 AM
Uber Member
i planned to make a ______ type bracket where the license plate would attach to. the bracket would run the full length of the top of the plate, with white leds in it. I figure i can fit about 12 leds in there to provide ample lighting.
if you want to keep the stock unit, you can rig about 8 leds (use higher powered ones) and put them on a board like this \_/ in the housing so that you get the angles needed....
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
