R/R Readings from Healthy System needed.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-31-2006, 10:06 AM Thread Starter
93VN750's Avatar
Does anyone have, or can anyone take both ac input (top three terminals) to r/r and both dc o/p's (left ground (for both dc readings), middle battery, right monitor) from r/r so I can compare to mine? Would like idle, 2k, 3k, 4k, and 5K rpm readings.
You can get meter leads right into the back of the r/r connector by removing the left cover. No further disassembly needed.
Thanks in advance for the help!!
Jon
93VN750 is offline
post #2 of 12 (permalink) Old 10-31-2006, 11:22 AM
If you don't get the readings I can always swing by and you can check mine.
Jon
artybolt is offline
post #3 of 12 (permalink) Old 10-31-2006, 11:39 AM Thread Starter
93VN750's Avatar
Arty -
If you have your bike at work, could you check them with a meter and either post or email them to me?
Picked up new battery (under warranty) yesterday so I want to see whats up before putting some miles on it.
Thanks,
Jon
93VN750 is offline
post #4 of 12 (permalink) Old 10-31-2006, 04:15 PM
Uber Member
there should be a listing under the vulcan versus. Also make sure u disconect the stator when getting the stator readings.... i forgot to do that and was worried
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 12 (permalink) Old 10-31-2006, 04:33 PM Thread Starter
93VN750's Avatar
I didn't see any r/r output data in the versus, then again, I have css, crs, and something else too....
I already have the stator data, I am looking to see what the r/r outputs are at the various rpm's to see if my charging system is working correctly.
I have new r/r and new battery, don't want to ruin either one of them.
Thanks,
Jon
93VN750 is offline
post #6 of 12 (permalink) Old 11-01-2006, 05:20 AM
Is this what you're lookin' for ......
Subject: Re: [VN750] Electrical Problem continues.
- How to check out the R/R
If you have the Kawasaki Service Manual, you will find R/R checkout on page 15-18. If you don't I will list what is there for you. Quoted from the manual as much as possible: Regulator/Rectifier Inspection Remove the left side cover. Pull out the connector. Be sure to set the hand tester to the 100 ohm range and zero the meter(Not necessary on a digital meter) Check the resistance between the regulator/rectifier terminals as follows(there is a chart and picture in the manual which I cannot reproduce right now but I will try to put it in words for you)
A1 A2 A3 All Alternator Terminals --- --- --- Connector with pins facing you and notch at bottom --- --- ---
G M B: G = Ground, M = Monitor, B = Battery --|__|-- (Hope that came across right)
Measure B to M - should read infinity
Measure B to G - should read infinity
Measure B to A1, A2, A3 - should read infinity
Measure M to B - should read > 10K ohm Measure
M to G - should read > 10K ohm
Measure M to A1, A2, A3 - should read > 10K ohm
Measure G to B - should read between 0.4 to 2K ohm
Measure G to M - should read between 1 to 5K ohm
Measure G to A1, A2, A3 - should read 0.2 to 0.6K ohm(200 to 600 ohm)
Measure A1, A2, A3 to B - should read 0.2 to 0.6K ohm(200 to 600 ohm)
Measure A1, A2, A3 to M - should read infinity
Measure A1, A2, A3 to G - should read infinity
If there is more resistance than the specified value, the unit has an open lead and must be replaced. Much less than this resistance means the unit is shorted, and must be replaced. Hope this helps someone out there.
post #7 of 12 (permalink) Old 11-01-2006, 09:03 AM Thread Starter
93VN750's Avatar
Hyper -
I already had this, I am looking for voltage measurements on the r/r as installed in a healthy charging system.
I used this to determine that my old one was bad.
But thanks.
Jon
93VN750 is offline
post #8 of 12 (permalink) Old 11-01-2006, 12:15 PM
Uber Member
well there isnt a way to measure voltage outputs of a r/r other then at the battery. this is cause the r/r will vary voltage to meet a perset goal. that is why you have to do the the stator test to verify that the stator is producing enough voltage. if your stator voltage is good, and your voltage wont go up with rpms topping out at shy of 15 volts, then you have a short in the electrical system. or a broken wire from the charging system
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #9 of 12 (permalink) Old 11-01-2006, 02:54 PM
Once Banned
cegodsey's Avatar
Maybe if everybody READ the question?
Could somebody with a good stator please measure the output at different rpms and report it here?
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #10 of 12 (permalink) Old 11-01-2006, 08:17 PM
Uber Member
oh, i would do mine, but that would be worthless, as mine is a moded stator anyway.
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
