Ever build your own eletrical parts? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 10-28-2006, 07:59 PM Thread Starter
Dead Dog
El_Taco's Avatar
I have a home made rectifier on my Honda, which cost about $12 to build. I'm looking at building my own solid state regulator. Has anyone done this on the Vulcan yet?
Hippie Dave
'86 VN750
'71 CB500K1
'74 CB550
'71 CB350
'71 SL350
More complete list to come....
'28 Essex Super Six
'41 Chevy Special Deluxe
'63 Buick Riviera
'65 Buick Riviera
'75 Camaro
'76 Chevy Monza
'76 Olds Starfire
'79 Monza Spyder
El_Taco is offline
post #2 of 7 (permalink) Old 10-28-2006, 08:05 PM
TrashLord's Avatar
I think you need to talk to Hizzo father and inventor of the (drum roll here)
FRANKENSTATOR
TrashLord
Connecticut
93 VN750
66K miles VROC#21253
Memphis Shades Demon Gradient Black Shield
leather cup holder
SOLD and missed
still got the cupholder waiting for next bike lol
TrashLord is offline
post #3 of 7 (permalink) Old 10-28-2006, 08:17 PM
93VN750's Avatar
Building a rectifier/regulator for our Vulcan's would be very straightforward if it were't for that 6th pin on the r/r, the monitor pin.
There's an undocumented control circuit in the r/r that controls the output of that pin. If we new what it did, or what the complete control circuti was, it'd be a different story.
Having looked at the insides of a KAW r/r, I think they used poor construction techniques and under sized components but have a circuit that works well.
Jon
93VN750 is offline
post #4 of 7 (permalink) Old 10-28-2006, 08:26 PM
Uber Member
i dont think anyone has actually made their own yet.... i was going to do my own if my stock unit couldnt handle the extra current from my stator mod. but it did, so i left it as i didnt have time to mess with it. Now IIRC on the OEM unit they have 3 diodes with thrysistors to regualate the voltage...... now there are much more efficent ways out there to do this... i suggest sticking with the trim style voltage regulation, b/c the voltage and ampage is to variant for other forms.
i suggest using 3 diodes to rectify the ac (i would say a 10-15 amp load each to be safe). then you can use a normal voltage regulator. now our system does require a voltage monitor that is comming back from the igniton switch as the wire in our bikes does a decent volt drop.
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 7 (permalink) Old 10-28-2006, 08:46 PM
93VN750's Avatar
Hizzo can you elaborate on the monitor pin circuit? Why is it there? WHat does it do? I think you'll need six diodes as it is three phase.
Jon
93VN750 is offline
post #6 of 7 (permalink) Old 10-29-2006, 02:37 PM Thread Starter
Dead Dog
El_Taco's Avatar
Sounds like a monitoring circuit to me. Once voltage reaches a specific point, it kicks th regulator out until it's needed again. I've had to retrofit R/R on smaller Kawasaki engines to use this type of circuit.
Hippie Dave
'86 VN750
'71 CB500K1
'74 CB550
'71 CB350
'71 SL350
'28 Essex Super Six
'63 Buick Riviera
'65 Buick Riviera
'75 Camaro
'76 Chevy Monza
'76 Olds Starfire
'79 Monza Spyder
El_Taco is offline
post #7 of 7 (permalink) Old 10-30-2006, 12:55 AM
Uber Member
Jon
yeah sorry, brain fart....i was thinking of using rectifing diodes which come in either pairs (4 diodes per unit) or singles (2 diodes per unit, and this is where i got my 3).
the monitor pin is for a Volt in. instead of monitoring off the output like most regulators, this set up uses as separate monitoring pin. They did that to over come the shotty wireing job they did. In some spots on the bikes electrical you can see over .5 volt drop. That can be rather important at idle speeds and so on if the regulator is only checking its internal output, and not checking externally.
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
