New Volt Meter - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 05-04-2013, 08:21 AM Thread Starter
chiller's Avatar
New Volt Meter
Got my new $19.95 volt meter from racetechelectric.com installed...nice. They have 2 different faces, black and silver. The silver looks like OEM equipment on our bikes.
Super easy to install.(see pics)
For the positive lead I used an empty accessories terminal on the fuse box which is switched on with the ignition. This is close to the battery and gives accurate battery voltage readings. It's the second one down from the top. Stripped the insulation off a female crimp on spade terminal so it would fit in the connector. Inserted it into the empty terminal hole in the fuse box connector then grounded the negative end on a chassis bolt. (see red arrows) Ran wires behind the dash panel, under the tank and back to the fuse box. Attached the meter with some super weatherstrip adhesive. No more guessing what my charging system is doing.
note: the electrical connector that plugs into the fuse box will only allow the individual wire terminals to go in 1 way. Look inside the plug to see which way it goes. The OEM wire terminals in the connector have lock tabs to keep them from backing out of the connector while plugging into the fuse box...the generic terminal I used (in the photo) does not. So once you push the connector into the fuse box, use something like a small screw driver to push the volt meter positive terminal back into the connector and into the fuse box mating terminal.
note#2: I tried using a relay instead of the direct off the accessories connection mentioned above. It gave me a much better reading on this meter...more accurate. Seemed to have some voltage drop when running through just the ignition accessories from the fuse box. I used instead the accessories to "switch" the relay and the LIVE battery accessories wires supplied from Kaw under the right side cover. A $4 relay from Advance auto worked great. Confused? PM me and I'd be happy to supply help and pics!
chiller is offline
post #2 of 19 (permalink) Old 05-04-2013, 12:50 PM
Pretty cool man. Did you attach it to the dash panel or the handlebar clamp/cover?
Old Bike: 2006 VN750 - Sold
eusjma is offline
post #3 of 19 (permalink) Old 05-04-2013, 12:54 PM
Good question, I too am curious, unable to tell by the pic.
tia
x2
post #4 of 19 (permalink) Old 05-04-2013, 06:46 PM Thread Starter
chiller's Avatar
It's attached to the handle bar clamp. That adhesive works very well. Got it from Advance auto in 1oz. tube for about $4. Only took a smidgen!
chiller is offline
post #5 of 19 (permalink) Old 05-04-2013, 07:52 PM Thread Starter
chiller's Avatar
Roughed up the bottom of the meter and the handle bar clamp a little with scotch brite to give the adhesive something to grab on to. Used electrical tape to hold the meter in place while the adhesive setup over night.
chiller is offline
post #6 of 19 (permalink) Old 05-04-2013, 07:59 PM
Nice !!!!!.....
post #7 of 19 (permalink) Old 05-04-2013, 10:39 PM
Can't find that one on their site, they show this digital one for $37.99, I still need one:
http://racetechelectric.com/i-852115...olt-meter.html
And this LED one for $44.95:
http://racetechelectric.com/i-856156...olt-meter.html
post #8 of 19 (permalink) Old 05-05-2013, 05:06 AM Thread Starter
chiller's Avatar
Try here:
http://racetechelectric.com/i-905268...voltmeter.html
Ask for silver or black...may need to call them to request.
chiller is offline
post #9 of 19 (permalink) Old 05-05-2013, 11:25 AM
And there it is, thanks!
post #10 of 19 (permalink) Old 05-18-2013, 06:48 AM Thread Starter
chiller's Avatar
Having connected up my volt meter, I noticed a substantial voltage drop to the meter, most likely because the fuse box accessory plug I used is switched through the ignition switch. Soooo...I installed a relay. Using the always hot (+-) leads under the right side cover to the relay and using the switched accessory terminal from the fuse box to turn it on. I connected the volt meter to the relay output and now have zero drop. I get the same meter reading using the relay as I do connecting the meter directly to the battery. Relay was under $5 from Advance Auto.
chiller is offline
