HELP! ELECTRICAL TROUBLE on my '86 Vulcan 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 05-02-2013, 01:04 PM Thread Starter
Working:
NEUTRAL LIGHT
TURN SIGNALS
Not Working:
Bike won't start.
Fuel Gauge inop.
Temp Gauge inop.
Headlight not working.
Brake light not working.
CHerrera is offline
post #2 of 13 (permalink) Old 05-02-2013, 01:13 PM
Ceal's Avatar
- Check fuses.
- Check ignition switch "hockey puck". You might need to disassemble, stretch the little springs a little, clean it up, check the wires soldered to it.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
post #3 of 13 (permalink) Old 05-02-2013, 01:18 PM Thread Starter
This is going to sound dumb as hell, but...where is the fuse box?
CHerrera is offline
post #4 of 13 (permalink) Old 05-02-2013, 01:35 PM
Fuses behind left side cover.
post #5 of 13 (permalink) Old 05-02-2013, 02:45 PM
Yep, the black junction box has a strip about 1 1/2" wide that pops out, fuses behind it.
post #6 of 13 (permalink) Old 05-02-2013, 04:33 PM Thread Starter
Thanks, Everyone.
CHerrera is offline
post #7 of 13 (permalink) Old 05-02-2013, 05:12 PM
Originally Posted by CHerrera View Post
Working:
NEUTRAL LIGHT
TURN SIGNALS
Not Working:
Bike won't start.
Fuel Gauge inop.
Temp Gauge inop.
After checking fuses, if no problem found, I would also suspect the Ignition Switch.
To open an Ignition Switch w/o knowing what to expect...would be a BIG mistake (method of dis-assembly & small parts).
Ensue to READ threads on forum on Ignition Switch / Puck prior to dis-assembly (and you will do fine) !
Also, check electrical connectors near gauge cluster.
WilliamTech
post #8 of 13 (permalink) Old 05-02-2013, 08:17 PM
Check all the "safety" switches/senders too....neutral, kickstand, etc.....I simply bypassed all mine....
post #9 of 13 (permalink) Old 05-03-2013, 01:11 PM
Captive New Yorker....
peterherrm's Avatar
I had crazy electric issues like that too. Would even make the engine misfire. Turned out to be the side stand safety switch. I defeated mine as well....
Pete Herrmann
Bought 4/2011 28k Miles,
New Rick's Motorsports R/R
Tim Parrot Stator
NGK Iridium Plugs
TOC MCCT's
peterherrm is offline
post #10 of 13 (permalink) Old 05-03-2013, 07:33 PM Thread Starter
After work, I got it to start and the Fuel Gauge, Temp Gauge, and Headlight were all operational again. So I don't think it's a fuse. I'm thinking an electrical connection or some kind of ground may be loose.
CHerrera is offline
