Determined to get tach working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-28-2013, 09:18 AM Thread Starter
The needle bounces a little bit. No real movement when I rev it. Bounces erratically when idles, up to 3000 and down, but no real reading. Checked all connections, cleaned and greased. Also check black to the coil and greased it. Still same thing. I did notice when I was taking it apart the metal bracket is broke, thought it was just loose, so I put a washer in it to stiffen it.. Obviously was hit. Temp gauge is fine, so do I need to replace the tach? How can I tell if it is the coil? Seems to be running fine. I am so confused.
jgerrard is offline
post #2 of 5 (permalink) Old 04-28-2013, 07:49 PM
if the front jug is firing, and the coil is working, I think the tach is fried.
It runs off the electrical signal from the front coil. If you are sure all the connections are good, then it might be a problem internal to the tach housing.
I don't think they are repairable, but then again I never opened one to try.
post #3 of 5 (permalink) Old 05-12-2013, 04:53 PM
You've described my tach exactly...please keep us informed once you do find the solution, be it a fix or a new tach.
brianhardy is offline
post #4 of 5 (permalink) Old 05-13-2013, 01:36 AM
What KC stated is 100% correct. Check all the wiring in between...if it ends up that it IS the actual tach, then any electronic/digital tach will work....all it basically does is measure the number of timees a cyl sparks/min vs the old style mechanical, which ran off a gear that measured crankshaft revolutions.
post #5 of 5 (permalink) Old 05-13-2013, 03:31 PM
Any recommendations on a new tach? Just wondering what works well/ looks good on our bikes?
MODS SO FAR...
Earshave/K&N pods
140/40 jets
Stator Redo by TPE
R/R Re-location
Pick-up coil mod
Corbin Seat
Kury Iso Grips
