Turn signal blink speed - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 37 (permalink) Old 10-19-2006, 07:24 AM Thread Starter
Geek
rnewell's Avatar
Cool Turn signal blink speed
My left turn signal blinks at a constant rate, what I would call normal. My right turn signal blinks at least 3 times faster. This just started in the last few days. The right turn signal used to blink at the same rate as the left one. Anyone have any ideas why ?? Waiting for Ernie the engineer .......
Ron from Jersey
HellFire windshield
Kaw extended backrest
Cobra exhaust
Re-located stator wires
Side bags
15,000 Miles July/2012
It's PAID OFF ! May 2009
rnewell is offline
post #2 of 37 (permalink) Old 10-19-2006, 08:04 AM
Search Goddess
Dianna's Avatar
Usually when you have a turn signal blinking faster than normal you have a bulb or partial bulb burned out.
Do a turn signal light check, checking all the lights for running and blinking conditions. (You do do that as a pre-ride check anyway, right?), Stock Front turnsignals are dual filament for running and blinking, rear stock are single filament for blinking only.
The only other condition would be if you had replaced some with LEDs and then you would need a load equalizer, but you didn't mention any recent replacements.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 37 (permalink) Old 10-19-2006, 08:20 AM Thread Starter
Geek
rnewell's Avatar
At 6 AM it's dark here so I didn't notice any lights out. Just went out and checked. ALL lights are working. With the motor off I can here the relay clicking faster on the right.
Ron from Jersey
HellFire windshield
Cobra exhaust
Side bags
rnewell is offline
post #4 of 37 (permalink) Old 10-19-2006, 03:14 PM
Uber Member
sounds like a short in the relay... try replacing it with a heavy duty flasher they are like 5-10 bucks and should fix your problem
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #5 of 37 (permalink) Old 10-19-2006, 03:36 PM
Once Banned
cegodsey's Avatar
I think Dianna got this one. The only other question - do both turn signals on that side blink fast?
You might try the cheap route first - replace both bulbs on that side. Just in case one is flakey. Then get a new flasher relay. Could be the built in capacitor or resistor is going out. Hard to say.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #6 of 37 (permalink) Old 10-19-2006, 06:56 PM Thread Starter
Geek
rnewell's Avatar
Both on the left are normal, both on the right are fast. I'll try the bulbs first.
Ron from Jersey
HellFire windshield
Cobra exhaust
Side bags
rnewell is offline
post #7 of 37 (permalink) Old 10-19-2006, 07:18 PM
Uber Member
oh, forgot to ask, is the fast blinking side brighter/dimmer then the normal side? also i just thought of this after cegodsey said Dianna won this one....
hizzo3 - 0
Dianna - 1
its ok i'll get the next one
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Hizzo3 is offline
post #8 of 37 (permalink) Old 10-19-2006, 07:56 PM
HAWK
Ccspinner's Avatar
We have teh same problem with Toyotas, the ground tab on the bulb gets week. When you have the bulb out look into the socket and there should be a small metal tab you need to bend out slightley and reintal the bulbs. It is the front bulb on Toyotas, cant say which one it is on the bike.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #9 of 37 (permalink) Old 10-19-2006, 10:13 PM Thread Starter
Geek
rnewell's Avatar
Both look the same to me...
Ron from Jersey
HellFire windshield
Cobra exhaust
Side bags
rnewell is offline
post #10 of 37 (permalink) Old 10-19-2006, 10:14 PM Thread Starter
Geek
rnewell's Avatar
Yea, thanks. I'll check that too. Keep it coming guys, and girls...
Ron from Jersey
HellFire windshield
Cobra exhaust
Side bags
rnewell is offline
