Grounding the Motor - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 04-22-2013, 07:15 PM Thread Starter
Grounding the Motor
SO I am working on build a 85 Vulcan with a 86 Vulcan 750 motor from the ground up, I bought this bike in pieces and incredibly (because I have very little knowledge about bikes) I have managed to get it almost all back together with just a few issues, one of them being the ground cable that is suppose to go to the motor. I don't know where the two locations to hook it up are, now I have the ground battery cable hooked up but I am having trouble wit this cable because it wasn't attached to anything I got the bike, it was just in a box of parts. I don't know the name of most technical things on the bike, as I said I just have common sense and it has got this far but I need to know where to hook up this wire. If ya'll could help me out I would be very grateful.
Bones432 is offline
post #2 of 4 (permalink) Old 04-22-2013, 07:28 PM
JM2001's Avatar
On the opposite side ( battery box ) of the battery ground cable you hooked up is a thru bolt to the right side of the battery box. The ground cable attaches there and is thru bolted to a bolt behind the coolant reservoir. On top of the transmission case you will see a casting with a round hole. The bolt to the left of it is where you ground the cable.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 4 (permalink) Old 04-22-2013, 08:53 PM Thread Starter
Thank you so much, that was a HUGE help
Bones432 is offline
post #4 of 4 (permalink) Old 04-23-2013, 07:22 AM
JM2001's Avatar
You're welcome.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
Tags
engine
