Bikemaster T/S Wiring Question.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-05-2006, 09:36 PM Thread Starter
93VN750's Avatar
I just bought some Bikemaster front T/S's for my bike.
They have three wires (as required), red, black, blk/wht.
Anyone know which wire is ground, running light, and blink?
Thanks,
Jon
93VN750 is offline
post #2 of 4 (permalink) Old 10-05-2006, 11:14 PM
Once Banned
cegodsey's Avatar
Get a 9 volt battery, use black as ground, then try the other two to see which is brighter. The brightest is the turn signal.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #3 of 4 (permalink) Old 10-06-2006, 12:31 AM
Uber Member
what he said. not any other way....well unless u wanna call them and spend an hour on hold with tech support
'04 Vn750
Currently Installed
nat'l cycle deflector shield
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #4 of 4 (permalink) Old 11-06-2009, 09:51 PM
BikeMaster T/S Wiring
I also purchased BikeMaster turnsignals and replaced all four signal lights. The front has three wires - striped connects with striped, red connects with gray and black connects with blue. The rear only has two wires - striped with stripe and the red with the other one. Hope this helps someone. The Bikemaster was only $17.56 each compared to OEM for $35.00 each.
FriscoJack is offline
