Is it the battery? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 04-11-2013, 12:26 AM Thread Starter
Tech/Musician/Friendly
AudibleCreations's Avatar
Is it the battery?
Got gas, go to fire the bike up and it doesn't want to start.... kept trying every 30 seconds or so and then the thing backfires.... eventually starts up with various rolls on the throttle and patience. Is it the battery and why does it backfire?
2000 VN750(A16)
*Richmond, Va*
25,000 Miles
Jetted, Shaved, Coastered
New Petcock
New Fuel & Vacuum Lines
New Plugs
Spline Lube
ACCT to MCCT
New Oil in Final Drive
Acid & Naval Jelly'd Gas tank
Luggage Rack
Hard Saddle Bags
Extended b*%ch Seat
(time for a new rear tire and state inspection)
AudibleCreations is offline
post #2 of 5 (permalink) Old 04-11-2013, 12:43 AM
SlowBox's Avatar
My bike did the EXACT same thing with the wet cell battery I bought it with. AGM battery fixed all my starting issues.
It backfires because the weak spark allows raw fuel into the exhaust.
SlowBox is offline
post #3 of 5 (permalink) Old 04-11-2013, 11:38 AM Thread Starter
Thanks SlowBox, I'll pick up the Manga Power 12v Sealed AGM 220CCA battery from Advance Auto today and rid this problem FOREVER! ($81.99)
2000 VN750(A16)
*Richmond, Va*
25,000 Miles
New Petcock
New Plugs
Spline Lube
ACCT to MCCT
Luggage Rack
Hard Saddle Bags
Extended b*%ch Seat
post #4 of 5 (permalink) Old 04-11-2013, 12:40 PM
I've been collecting data...here is the latest on AGM Batteries...
Manufacturer - Model - CCA Availablity -Additional Notes
BatteriesPlus X2-15L 210 BatteriesPlus Deka ETX15L re-branded- - $95.00 Store-Nov-2012
Big Crank ETX15L 210 Online Retailers, eBay Deka ETX15L re-branded --- Ebay - $68.00 Nov-2012
Deka ETX15L 210 Online Retailers, eBay
Die Hard 44005 210 Sears YUASA YTX14AHL-BS re-branded $80.00-Store Nov-2012
EverStart ES14AHBS 210 Walmart Terminals are swapped, so install backwards and remove bottom spacer.
Interstate CYTX14AHL-BS 210 Retailers YUASA YTX14AHL-BS re-branded
MagnaPower ETX15L 210 Advance Auto Parts Deka ETX15L re-branded -
Manga Power 12v Sealed AGM 220CCA! ($81.99 Ė April 2013)
WestCo 12V14L-B 220 WestCo
YUASA YTX14AHL-BS 210 Online Retailers, eBay $78.00 online Dec-2012 ----$88.00 Dec-2012
Magma Power ETX15L 220 CCA Advance Auto Parts 220 CCA $77.00 - Online -Take 15% off -Enter code DEM11 at checkout. Online Only.
NOTE: Ebay / Online prices quoted above are from a single online search, additional searchís may produce different prices.
post #5 of 5 (permalink) Old 04-11-2013, 02:00 PM
Ceal's Avatar
I have the EverStart from walmart, I think it cost me around $70. Still going strong after 2-2.5 years. Just recently I let my bike sit for around 6 months and the battery still had a charge... I drained it because my coils weren't firing, but after fixing the coils and recharging the battery on a battery tender, the battery was brought back to life and hasn't failed me.
1985 VN700 unknown mileage (over 33K)
AGM Battery
Iridium spark plugs
NGK wires and caps
Ceal is offline
