Fuse box connection - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-04-2013, 06:40 PM Thread Starter
davidfite1978's Avatar
Fuse box connection
Do I need to replace my fusebox and/or this connection?
\m/ Jaymz \m/
SOLD! 1999 Vulcan 750 | Pics (bought 3/29/2013 with 5657 miles)
Upgrades: MF/AGM Battery|Kaw F&S Luggage Rack|Kaw F&S Windshield|NGK Iridium plugs DPR7E1X-9|Kaw F&S Saddlebag Supports & Turn Signal Relocators|River Road saddlebags
Fixes: Repainted battery cage|Replaced bent clutch lever|Replaced left headlight bracket|Splines lubed and new tires @ 6,000mi.|Sold @ 6320 miles on 10/28/2013
davidfite1978 is offline
post #2 of 8 (permalink) Old 04-04-2013, 06:42 PM Thread Starter
Phone only let me attach 1 pic at a time.
\m/ Jaymz \m/
post #3 of 8 (permalink) Old 04-04-2013, 06:52 PM
JM2001's Avatar
I would replace both for sure. Better to be safe than sorry.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 8 (permalink) Old 04-04-2013, 06:54 PM Thread Starter
Can I just cut off the connector and solder a new one on? Will everything still operate ok?
\m/ Jaymz \m/
post #5 of 8 (permalink) Old 04-04-2013, 07:03 PM
JM2001's Avatar
The metal female connectors are just a press fit with a locking tab. If your wires are good you could just replace the metal connectors. Your plug seems to have over heated and melted. That's why I would replace yours. Your junction box looks like you have a lot of corrosion inside of it. That could cause a lot of problems.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #6 of 8 (permalink) Old 04-04-2013, 08:20 PM
First a question to David.
Are you having electrical problems with it right now?
Or is this preventative maintenance?
That 12 wire plastic connector does not look melted to me.
The bottom right side female metal terminal looks corroded/rusty and matches one of the male connectors in the fusebox/juncion box.
You could try cleaning them (both male and female contacts) with plastic safe electrical contact spray cleaner and rub with a Q-tip, wooden tooth pick, small piece of sandpaper or an old point file etc, etc, to see if it will clean up.
OR you might just need to replace one or two of the female ends on the wires, and clean male contacts as mentioned above.
post #7 of 8 (permalink) Old 04-04-2013, 08:37 PM Thread Starter
No problems. Just bought the bike 2 weeks ago, was going to replace battery and noticed the battery crapped all over everything, so I wanted to get it cleaned up. I just got everything unplugged and took the battery cage out. I think I'll try and clean the connectors first and see how it goes. Maybe next winter will replace the fusebox and/or connectors...
\m/ Jaymz \m/
post #8 of 8 (permalink) Old 04-04-2013, 09:21 PM
Chucklehead
dragon159's Avatar
If there are no electrical issues I'd clean with contact solvent and use dielectric grease when I put it together. Just try to remember it if issues occur later.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
