running bike with no battery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 03-22-2013, 07:29 AM Thread Starter
scrmn3agle
Ok, here's what I got. I know I essentially have a bad battery too, but the other day while I had it out I took my Jumpit and started the bike up. The problem is when I turned the switch off on the Jumpit the bike cut off. I did the charging check per Denny and everything checked good. I remember from working on cars that you could check the system out by disconnecting the battery and see if the car still runs. Is there something different on the bike or do I have another problem?
scrmn3agle is offline
post #2 of 4 (permalink) Old 03-22-2013, 07:50 AM
From what I remember being told. This bike anyway, needs a voltage source aka a battery or your jumper to run. When you eliminate that source, it won't run.
Correct me if I'm wrong but I'm pretty sure I've got it right.
Denny's a good source to help you trouble shoot electrical stuff. I'd trust what advice & guidance he gives.
post #3 of 4 (permalink) Old 03-22-2013, 08:14 AM
Bike will not run without a battery.
post #4 of 4 (permalink) Old 03-22-2013, 08:50 AM Thread Starter
scrmn3agle
Good deal. Thanks for the relieving info
