emergency roadside assistance requested - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-18-2006, 01:03 PM Thread Starter
rider
global_recon's Avatar
Hey guys! This is Paul's sister writing on behalf of Paul. 100 miles into his trip, he had a problem and he wants to get some advice. The bike was running fine, although he still has the bungy on the key because the ignition switch fix didn't hold. When he stopped to get gas, he shut the bike off and then when he tried to start it, the engine wouldn't turn over. He said it almost seemed as if the battery didn't have enough juice to turn the engine over, but the volt meter is reading 12.6 volts with the bike off. He let the bike sit for 1/2 hour, and then tried again and had the same problem. After that, he tried jump starting it and wasn't able to start it because he couldn't get the bike up to adequate speed. Immediately after that, he tried the starter button again, and the engine started fine. At 5000 rpm, the engine is putting out 13.6 volts so it seems like the charging system is working. He shut off the engine and tried again and it started fine. He decided (rather than turn around) to continue his trip to Florida, but will be calling back to see if anyone had any ideas. Thanks a lot for any input!
paul
1991 vn750: 'for great justice'
http://www.globalrecon.org
follow my rides on twitter: http://www.twitter.com/globalrecon
global_recon is offline
post #2 of 6 (permalink) Old 09-18-2006, 01:06 PM
where is he now? and does he have a cell phone to call for help if he needs it?
kait is offline
post #3 of 6 (permalink) Old 09-18-2006, 01:38 PM Thread Starter
rider
14 miles down the road, Paul is at a rest stop and he thinks he knows the problem. The ignition switch issue is causing the bike to shut off as it is going down the road and when that happens, the voltage spikes to 17 or 18 volts. We're going to try to get the bike back to Winston-Salem in a pick-up truck.
paul
post #4 of 6 (permalink) Old 09-18-2006, 01:51 PM
glad to hear he is okay and has an idea of the problem.. have him get on line with us when he gets back.
tell him to be safe.
kait
kait is offline
post #5 of 6 (permalink) Old 09-18-2006, 05:04 PM
Once Banned
cegodsey's Avatar
Ignition switch. Makes sense, seeing how that is where the problem started. Other than that, it sounds like either the ground isn't grounding, or the positive isn't, um, positively? The bike won't run without the battery, and it sounds like this is what is happening. Ignition switch could definitely do that.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #6 of 6 (permalink) Old 09-18-2006, 07:19 PM Thread Starter
rider
thanks for the responses, guys. i'll continue this thread back over at the original... here.
paul
