soldering stator wires - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-15-2006, 08:44 PM Thread Starter
kait's Avatar
Question soldering stator wires
During my day long trip to the shop today (where I got to watch a Harley clutch being replaced, a race car having its carbs synched and its valves adjusted) I had them look at the connections from my stator to my r/r. They suggested that I have them soldered (sp?) instead of the butt connectors replaced. I hope I didn't BUFU it by having them do this! They said it would keep the melt-down from happening again, and that they do a lot of Goldwings the same way.
Any comments by the peanut gallery on what advantages this has over the connectors?
My Blog:
http://kaitbr.blogspot.com
VROC #21146
Mods and other stuff:
nat'l cycle deflector shield
final drive splines lubed 8/06
replaced broken speedometer cable (5194 miles) 9/06
Vehicles:
95 S-10 Blazer 187K miles (Black and Silver)
01 Kawasaki VN750 3300+ my miles, 5300+ total miles (Black and Silver)
04 John Deere L118SE Riding Mower w/ snow plow (John Deere green and yellow)
kait is offline
post #2 of 8 (permalink) Old 09-15-2006, 09:22 PM
fergy's Avatar
Just that the connectors will eventually start to corrode and will weaken your voltage going through the corrosion (resistance). The soldered connections should be trouble free.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #3 of 8 (permalink) Old 09-15-2006, 09:29 PM Thread Starter
kait's Avatar
Wooohooo! I did something right! Glad to hear it Fergy.
My Blog:
VROC #21146
Vehicles:
kait is offline
post #4 of 8 (permalink) Old 09-15-2006, 10:29 PM
Once Banned
cegodsey's Avatar
Yeah, OK. I'll go with Ferg's answer.
2000 A16
Drilled baffles
$65 leather saddle bags
Kuryaken grips
relocated R/R
de-badged
25,000+ original owner miles
cegodsey is offline
post #5 of 8 (permalink) Old 09-16-2006, 12:35 AM
Uber Member
yep... in case if anyone wants to do this themself this is what you need.
1) silver soder from radio shack (the lower stuff breaks up to easy)
2) a >15 watt sodering iron (30 watt works great)
3) liquid electrical tape or any type of expoy, potting compound or you could even try RTV silicone
i wish they did a hard wire from the R/R in the first place... would save so much time and money
Take the wire and place some through the hole in the R/R spade and the other wrap around the terminal... then heat the wire with the iron. place the soder on the wire and let the wire melt the soder, not the iron melt the soder. Do this for each connection and your set.
**note, you should only have to hold the iron to the connection for a few seconds (<@10), holding it too long can burn the insulation on the wire, indicated by a burnt plastic smell!
'04 Vn750
Currently Installed
R/R relo
TOC ACCT's
Mez's 110-FRT 170/80-Rear
Hizzo3 is offline
post #6 of 8 (permalink) Old 09-16-2006, 12:37 AM
HAWK
Ccspinner's Avatar
Better than the liquid tape is heat swhrink tubing, thats what I used and it is waterproof and last longer than liqiod tape or rtv.
Chad Falstad "Hawk"
Vroc #17649
2011 HD Ultra Classic "angel"
Ccspinner is offline
post #7 of 8 (permalink) Old 09-16-2006, 12:58 AM
Once Banned
cegodsey's Avatar
OK, I'm confused already. Everytime I hold the soldering iron, I get a burnt fleshy smell. And it is really hot. Well, it was only really hot the first time. I can't feel the heat now.
2000 A16
Drilled baffles
Kuryaken grips
relocated R/R
de-badged
cegodsey is offline
post #8 of 8 (permalink) Old 09-16-2006, 01:01 AM
HAWK
Ccspinner's Avatar
Try turnig it around
Chad Falstad "Hawk"
Vroc #17649
