Stators....Does anybody know... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 03-11-2013, 11:57 AM Thread Starter
I am about ready to send my stator in for a heavy duty rewind.
It was still functioning when my engine went to H*LL, ......upon tear down, I discovered a few of the stator plates had shifted (has become out of alignment) in/on one section.
QUESTION: Do they rewind my Stator, or send me another (already) rewound stator ?
Is my stator repairable/rewindable ?
any thoughts will be appreciated.
thanks in advance
WilliamTech
post #2 of 15 (permalink) Old 03-11-2013, 12:14 PM
It really depends on the shop. I've seen some that wind on demand and some that have inventory. If they already have one, that's good for you because its less turnaround time.
post #3 of 15 (permalink) Old 03-11-2013, 12:50 PM
I read somewhere... If you contact TPE you can send pics and they'll tell you if it looks like they can rewind your stator or if it's good enough to use as a core.
post #4 of 15 (permalink) Old 03-12-2013, 01:21 PM Thread Starter
Posted pics of my damaged Stator in my album of "Damaged Balance Gear.....
Examining the construction of stator, I would think this stator IS rewindable.....
post #5 of 15 (permalink) Old 03-12-2013, 11:58 PM
Are you sending it to Tim Parrott?
I asked a local rewind shop what it would cost to rewind mine.
It would have cost $2-300. About twice as much as a new one from a dealer.
TPE would still be the best deal even for me up here north of the 49th.
post #6 of 15 (permalink) Old 03-13-2013, 10:18 AM
I spoke to TPE last year about my buddys stator, I'm pretty sure you send it in and you get the same one back, although I believe he does have some ready to go too.
post #7 of 15 (permalink) Old 03-13-2013, 11:20 AM
looking at the photos...IMO it is not useable...but I am no expert.
I wouldn't feel comfortable re-using that one since the end plates are deformed. It could start another chain reaction if a piece hits or comes loose in there.
post #8 of 15 (permalink) Old 03-13-2013, 01:16 PM Thread Starter
Yeah, I don't think I'll chance it with a Rewind. I do have another Stator to send TPE.
Next question... I desire to obtain TPE's High Output Stator...
Will the stock R/R handle the High Output Stator ?
tia
post #9 of 15 (permalink) Old 03-13-2013, 02:31 PM
tia
That is sort of a subjective question William...in theory it should.
The R/R will shunt what is not used....so it depends on how much extra output you get from the high output stator, and if you are adding any loads to require the extra output.
If you add amperage from the stator, the regulator will be required to "shunt" more power if you are not using the extra power as added accessories. This will cause the R/R to run hotter....not sure of the limits of the shunting ability of the stock stator. but it will obviously cause some stress.
What is your setup...meaning:
What is the extra amperage you are adding
What added items have you added to the stock system in the way of current draw?
If you balance the added power with added current draw, then you should be fine.
post #10 of 15 (permalink) Old 03-13-2013, 03:12 PM Thread Starter
My thoughts:
When replacing the Stator, why not replace with a Heavy Duty/High Output one.
I have a gxtreme manufactured Tuxedo Style Stator Mod plate to install as well..
In time, I will be adding two more driving/headlights, (KC's light Bar) but do intend to go all LED tail & turn lights. I have an Air Horn as well.
