So what lights are on ... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 03-09-2013, 09:41 PM Thread Starter
What lights are on key on, engine off? Key on, engine on? OEM. Is there a light switch?
wmsonta is offline
post #2 of 9 (permalink) Old 03-09-2013, 09:56 PM
JM2001's Avatar
There is a high-low beam switch but not one to turn the headlight on or off. The light comes on automatically when the engine fires and activates the headlight relay. Some of us have bypassed the relay and the light comes on when you turn the key to on. The headlight relay robs a lot of power going to the battery.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 9 (permalink) Old 03-09-2013, 10:00 PM
romeobravo172
romeobravo172's Avatar
Key on engine off--oil/neutral/front running lights/tac-spedo fuel back light/red rear running and tag light
Key on engine running/ all of the above plus head light.
The white head lamp in the dash people says light up also but is so faint you can't see or at least I can't
romeobravo172 is offline
post #4 of 9 (permalink) Old 03-09-2013, 10:06 PM Thread Starter
Great responses. Thank you both.
wmsonta is offline
post #5 of 9 (permalink) Old 03-09-2013, 10:13 PM
My lights are on, but nobody's home......now THAT is the best response and most honest, lol....
post #6 of 9 (permalink) Old 03-09-2013, 10:17 PM Thread Starter
I do not have a single light, key on engine off. I am going to guess a fuse and I know why. Now if I can find the fuse panel. Think a owners manual would help?
wmsonta is offline
post #7 of 9 (permalink) Old 03-09-2013, 10:22 PM
romeobravo172
Inside left side cover
post #8 of 9 (permalink) Old 03-09-2013, 10:58 PM
...prolly have a short, and it blew the 30 amper....
post #9 of 9 (permalink) Old 03-10-2013, 12:02 PM Thread Starter
Thanks all. It also was in the downloaded manual, just hidden. Nothing in the manual says what lights are on. PO wired his own license plate tiny bolt lights.
wmsonta is offline
