water in sparkplug whole - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-05-2013, 12:06 PM Thread Starter
Anyone know what to do about water standing in the rear right spark plug whole? it getting to be a real problem the plug is fouling, the whole is filling with rust. seems like if i park on the kickstand the lean of the bike allows rain to get in the whole and stand. in suggestions, besides using the center stand LOL
hhead51 is offline
post #2 of 10 (permalink) Old 03-05-2013, 12:20 PM
Im guessing you park your bike outside, so how about a bike cover?
jj23 is offline
post #3 of 10 (permalink) Old 03-05-2013, 01:02 PM
on the back of the engine near the exhaust manifold there is a small hole
that hole is the drain for the spark plug tube and is probably clogged up
jab at it with a small pick and open the passage up maybe even some wd 40 and compressed air when it is clear you should be able to pour water in the sparkplug tube and watch it drain off the back of the engine
post #4 of 10 (permalink) Old 03-05-2013, 01:04 PM
There has to be a drain hole that is clogged up. Try compreesed air and blow out the dirt and build up around plug.
post #5 of 10 (permalink) Old 03-05-2013, 01:04 PM
oh and a bike cover wouldnt be a bad idea either
post #6 of 10 (permalink) Old 03-05-2013, 01:07 PM
Your weep hole must be plugged. There is actually a drain hole in there that is supposed to allow any water or heaven forbid oil to drain out.
I had encountered this myself a few years back as I found one of the O-rings to the spark plug well was letting oil in there & was leaking out the weep hole.
I would clean out the excessive water & first with an air line blow in there to try & break the blockage free. if this doesn't work, go at it from the other side & blow into the well.
This pic is of the front one but the rear is similar, just on the other side.
post #7 of 10 (permalink) Old 03-05-2013, 01:10 PM
Damn, look at you all getting in there before I could finish my post. lol
post #8 of 10 (permalink) Old 03-05-2013, 02:20 PM
Yea but we all stand in awe of your pretty, colorful pictures
jj23 is offline
post #9 of 10 (permalink) Old 03-05-2013, 07:43 PM Thread Starter
well after a lot of looking and a trip to the kaw shop 20 miles away, there is no drain hole. i pulled the plug just to be sure there is no hole inside the spark plug chamber.. i'm going to find a spark plug cap to cover the plug chamber
hhead51 is offline
post #10 of 10 (permalink) Old 03-05-2013, 10:17 PM
Since this is the rear head we are looking at you will have to pull the coolant overflow tank to get at the hole there is a drain hole on all the vn750 heads it is drilled in when the head is made at the plant most bike shop are clueless when it comes to our bikes
