Buzzing from the fuse panel - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 02-26-2013, 12:52 AM Thread Starter
Hello, I have buzzing coming out of the fuse panel. If I pull out the 30 fuse in the center it stops.
While buzzing all signals headlight and horn works. The engine also fires over and runs.
???? All the fuses look good. Any help is greatly appreciated. thanks
Mrcorso is offline
post #2 of 3 (permalink) Old 02-26-2013, 01:07 AM
There are relays mounted inside the Fuse Box.
The "Fuse Box" is namely the "Junction Box".
The buzzing, I would guess is a relay trying to go faulty.
post #3 of 3 (permalink) Old 02-26-2013, 06:45 AM
JM2001's Avatar
Are you sure it's from the junction box and not on top of it? Pull the turnsignal flasher relay and see if the buzzing stops. That could be your problem.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
