Stator connection - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 02-22-2013, 02:18 PM Thread Starter
kemen3's Avatar
Stator connection
Quick question. I am replacing the connections on the stator to rectifier (the yellow wires). I have some bullet connectors from Radio Shack. Will those work for that or do i have to have a special kind? I was going to use them, then seal them with heat shrink tape.
Sent from my DROID BIONIC using Motorcycle.com Free App
kemen3 is offline
post #2 of 14 (permalink) Old 02-22-2013, 02:22 PM
U can accually solder the wires together for a better connection. And use heat shrink for insulation.
post #3 of 14 (permalink) Old 02-22-2013, 02:24 PM
I have no experience with them on the stator wires, how well will they stand up to the heat ? .....many VN owners prefer to solder the connections, insulate with Heat Shrink tubing.
post #4 of 14 (permalink) Old 02-22-2013, 02:44 PM
Yes on the solder & if you need to change the stator down the road just unsolder them.
post #5 of 14 (permalink) Old 02-22-2013, 03:00 PM
I think they're easier to get to if you pull the coolant tank.
post #6 of 14 (permalink) Old 02-22-2013, 03:05 PM
I don't k ow why folks keep saying that. The coolant tank is on the other side of the bike!?
post #7 of 14 (permalink) Old 02-22-2013, 04:17 PM
If you use bullets...they should be soldered to the wires, other wise don't bother. It just adds places for the connection to corrode, heat up , and fail.
EDIT: I wouldn't trust anything Radio Shack sells...JMO you would probably be better off soldering them together and heat shrinking it.
post #8 of 14 (permalink) Old 02-22-2013, 05:13 PM Thread Starter
kemen3's Avatar
Re: Stator connection
I will solder them and heat shrink them thanks everybody
kemen3 is offline
post #9 of 14 (permalink) Old 02-22-2013, 07:19 PM
Might wanna go up one gauge in wire too...them things are aweful thin.
post #10 of 14 (permalink) Old 02-22-2013, 07:51 PM
On my bike at least, the wires come farther out on the right side of the bike (behind the coolant tank) or at least your hands can reach them better. On the left side I had to reach around the exhaust pipe with my left hand and there wasn't much room for the right hand.
For soldering, I just found it easier to reach the wires with both hands and not have anything in the way. You still have to route the wires up the left side when you're done soldering.
