Turn signals mod LED - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 02-19-2013, 02:20 PM Thread Starter
I saw on one of Slovenian web stores led lights on round shape.
so i decided to modified turn signals.
here are results:
http://www.youtube.com/watch?v=Y6iXOGmrM90
manhunter05 is offline
post #2 of 7 (permalink) Old 02-19-2013, 06:57 PM
Okiebezer's Avatar
I like that! Nice and bright. Do they stay facing lense or rattle around in housing due to size?
Okiebezer is offline
post #3 of 7 (permalink) Old 02-20-2013, 01:53 AM
Ndr
Looks nice an bright there. How is it with the lens on?
I too would be curious about how the LEDs move around with all that space there. I'd be tempted to pour in some resin or some such to hold them solidly in place.
Ndr is offline
post #4 of 7 (permalink) Old 02-20-2013, 02:34 AM Thread Starter
the LED plate is so light that cables itselfs holds it in place. Otherwise, I found a rubber tube, which I will use as a spacer, with little bit a super glue.
Pictures to follow.
post #5 of 7 (permalink) Old 02-20-2013, 06:38 AM
Looks good. To hold it in place I would consider hot glue over super glue. Hot glue will hold well and even absorb some vibrations. I too wonder just how bright they are with a lense on.
post #6 of 7 (permalink) Old 02-20-2013, 10:54 AM
I am just curious what the current draw would be on those high power LED's?
I would think they draw a decent amount of current, but I could be wrong.
Do you have specs or a part number for that?
I make an LEd board (in my signature) that is plug and play and also draws significantly less current than a stock incandescent bulb without generating much heat.
I am just curious how efficient they are.
post #7 of 7 (permalink) Old 02-20-2013, 03:34 PM Thread Starter
its good idea about, but rubber hose absorb enough vibration, so super glue should be enough.
@kc2dgq
Type: G4 9smd 5050
Power: 1,5 W
Connection: G4
Brightnes: 100 lm
Color : 3000 K - warm white
10 - 30V DC
what do you think?
http://www.tehnoled.si/g4/g4-led-zar...w-12v-1-detail
videos and pictures later
