I need help! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 02-14-2013, 11:06 PM Thread Starter
lvpreacher's Avatar
I need help!
Yesterday out of the blue my headlight quit working and rear turn signals don't light up. (turn signals do blink when on). Checked headlight bulb and it is good. Checked fuses and they are fine. Any help would be appreciated.
1993 Vulcan VN750
Purchased August 2012 w/ 5700 miles
Big Crank ETX15L AGM Battery
NGK Iridum Plugs
lvpreacher is offline
post #2 of 2 (permalink) Old 02-14-2013, 11:38 PM
i would start by jumping the blue wire in the 8 pin connector of the junction box over to the empty slot in the same connector they should be side by side if the headlight works then i would say your headlight relay is bad as far as the rear turn signals go if they are stock then they are not running light/turn signals like the front are the rear only illuminate when the blinker is on (normal operation)
