Electrical Mystery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 01-17-2013, 03:27 PM Thread Starter
mnich797's Avatar
Electrical Mystery
Put bike up on center stand to install new exhaust. Took it off center stand and
presto starter button does nothing. I have a loud horn and bright lights so appears plenty of battery. Not a click nothing. Is there some sort of safety switch on the center stand?
1993 VN750
Purchased 12-26-2012
DPR7EIX-9 Iridium Spark Plugs
De-Goated
Rear Turn Signals Relocated
Splines Lubed
Mac 2 into 2 Staggered Exhaust
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
post #2 of 13 (permalink) Old 01-17-2013, 03:50 PM
Deviate's Avatar
While putting on the new exhaust could you have knocked loose the wire going to the starter?
Leave it to me to NOT be fond of something then end up banging it.
Deviate is offline
post #3 of 13 (permalink) Old 01-17-2013, 03:52 PM
Neutral switch.....
dariv is offline
post #4 of 13 (permalink) Old 01-17-2013, 03:54 PM
Not possible. I've messed with my exhaust to know that the wiring for the starter is not near enough to be in the way.
dariv Neutral switch.....
Highly probable. Or possibly the sidestand switch is stuck.
post #5 of 13 (permalink) Old 01-17-2013, 04:01 PM
Can't be sidestand either.... The starter relay goes through the clutch switch first then the neutral switch to ground...
dariv is offline
post #6 of 13 (permalink) Old 01-17-2013, 04:05 PM
Did you check your kill switch? Maybe forgot to turn that back on? I know it sounds obvious, but sometimes the simplest solutions are overlooked.
post #7 of 13 (permalink) Old 01-17-2013, 04:11 PM
how about holding the clutch in, does it start then? Just wondering.
kenny
Mercury is offline
post #8 of 13 (permalink) Old 01-17-2013, 04:32 PM
Ive actually done that a few times when wearing gloves....accidentally flipped it to off,lol...tore my hair out. Now its the first thing I check, lol.
And the wire to the neutral switch is right under the tranny (single green wire), so messing with the exhast very well could have done it. Its not well protected.
post #9 of 13 (permalink) Old 01-17-2013, 06:12 PM
Arrow
x2.... Yeah, this is the first thing that came to mind...exact symptoms !
post #10 of 13 (permalink) Old 01-21-2013, 02:49 PM Thread Starter
mnich797's Avatar
After the Flu
Finally got back to the bike today after a bout with the damn flu. Kill switch in run position checked neutral switch wire, attached played with clutch switch, she fired right up. Just tried it again nota. I noticed three wires in the connector is there a way to bypass the clutch switch?
1993 VN750
De-Goated
Splines Lubed
TOC MOD
AGM Battery
Racetech Voltmeter
Coil Relay Mod
mnich797 is offline
