My headlight is horrible!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Closed Thread
post #1 of 108 (permalink) Old 01-09-2013, 01:08 AM Thread Starter
Question My headlight is horrible!!!
my headlight is uper dim. Its not the lens it is super clear. Anybody have any idea what type of bulb fits the bike?
odom_austin is offline
post #2 of 108 (permalink) Old 01-09-2013, 02:17 AM
By chance, is the white block on dash lit up? If so, means reserve lighting system has kicked in. I believe it uses an H4 size bulb.
post #3 of 108 (permalink) Old 01-09-2013, 06:21 AM
SilverStar Ultra 9003/HB2 H4 Headlamp available from Walmart
post #4 of 108 (permalink) Old 01-09-2013, 09:36 AM
Bah........ Go HID
dariv is offline
post #5 of 108 (permalink) Old 01-09-2013, 11:31 AM
forget silverstar and all the other nonsense, they are still a 55W/60W bulb. These are not 'legal' for on road use, but ill tell ya what my 80W/100W bulbs are brighter then all the nonsense they sell in the stores. Blue light / silverstars are not brighter, blue light just looks brighter because the eye is more sensitive to that light range from what I understand. The best light is clear white light and that is exactly what this light will do.
I have the 80/100W version on my bike and as long as the housing and wiring can handle it - its worth it
http://www.ebay.com/itm/PHILIPS-9003...-/130677807582
kenny
Mercury is offline
post #6 of 108 (permalink) Old 01-09-2013, 11:42 AM
Originally Posted by Mercury View Post
....I have the 80/100W version on my bike and as long as the housing and wiring can handle it - its worth it
And there is the rub......... At 100W your looking at about 8A .... and that has to go through your hi/lo switch too.....
dariv is offline
post #7 of 108 (permalink) Old 01-09-2013, 11:47 AM
Have you checked the voltage at the headlight connector?
dariv is offline
post #8 of 108 (permalink) Old 01-09-2013, 11:55 AM
I have had a 80/100W in my bike since 06, no issues and 50K miles later.
I have a 800cc though, may be different then the 750's. I hope Kawasaki would use a hi lo switch that is rated more then the precise current they would be switching.
I agree that a good check is to check the voltage at the bulb. Maybe the bulb is just on its way out?
Mercury is offline
post #9 of 108 (permalink) Old 01-09-2013, 12:00 PM
^ the 750 electrical system is weak to begin with.....
I rewired my headlight so power went straight from the battery to the headlight via a SPDT relay. The relay was energized by switching to high beam. The NC contact went to the low beam, and the NO contact went to the high beam. So even if the switch or relay failed, the low beam would always work.
dariv is offline
post #10 of 108 (permalink) Old 01-09-2013, 12:10 PM
Keep in mind that the power output of the bulb is dependant on the input voltage..... in other words, a 100W bulb is only 100W at a certain voltage...
Also, remember that power output is proportional exponentialy to the voltage... P=V^2/R
So a bulb rated for 100W at 14VDC, is only 73W at 12VDC....
dariv is offline
Closed Thread
