Bike won't start - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 12-28-2012, 01:00 PM Thread Starter
Bike won't start
Took the seat off to replace the petcock. And now it wont start.
Battery is charged, dash lights come on, its in neutral, and blinkers work.
Headlight doesnt come on and when i go to start it nothing.
Thanks in advance for the help
d5h1znt is offline
post #2 of 10 (permalink) Old 12-28-2012, 02:11 PM
Headlight doesn't come on and when i go to start it nothing.
Proper operation, the headlight will be held off until bike starts (With output of stator Headlight will come on).
>>>>>>>>>>>>>> Q: Is the bar kill switch turned on ? <<<<<<<<<<<<<
Q: Is the bike in gear ?....if so, pull the clutch in.
EDIT: What year is the bike ? Does it have a side-stand switch ?
post #3 of 10 (permalink) Old 12-28-2012, 09:18 PM
Does it turn over but not start, or does it not even turn over?
dariv is offline
post #4 of 10 (permalink) Old 12-28-2012, 09:20 PM
Oh, check the connector at the clutch switch, the ground path goes through the clutch switch first, then the neutral switch...
dariv is offline
post #5 of 10 (permalink) Old 12-28-2012, 10:38 PM
That and that kickstand safety switch...I cut all mine off/bypassed...not recommended for a new rider...
post #6 of 10 (permalink) Old 12-29-2012, 08:21 AM
^ only if it turns over but doesn't have spark.
The side stand can be in either position for the bike to crank (because if the bike stalls on the road, you wouldn't want to need the stand down to start it)
dariv is offline
post #7 of 10 (permalink) Old 12-29-2012, 04:28 PM
Well, the sidestand switch regulates the spark (not the cranking)...I know that from experience with KC as a witness...my bypass splice went bad when we were ridin, and it would crank with stand up/down...soon as I fixed the splice, it fired right up....also, while we were riding, the connection began to come loose....the bike acted exactly as though there were no spark, then would kick in again...
Now, this is on my '85...mebbe the newer ones were different, but doubt it...
KC...remember that hot mama that stopped to talk to us when I was workin on the bike ?...man...aint seen her since....
post #8 of 10 (permalink) Old 12-29-2012, 04:53 PM
^ exactly, the stand is for spark only.
dariv is offline
post #9 of 10 (permalink) Old 01-02-2013, 10:12 AM Thread Starter
it was the neutral switch. thanks everyone
d5h1znt is offline
post #10 of 10 (permalink) Old 01-03-2013, 01:32 AM
No problem, glad to help...
dariv is offline
