Battery is dead - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 12-27-2012, 03:35 PM Thread Starter
Battery is dead
Got a brand new sealed AGM battery a couple of weeks ago. Bike started right up, but I haven't ridden it since. Well I checked it a couple days ago and the battery was completely dead. I figured there was a short in the bike somewhere. Any advice of where I should go from there?
numb0617 is offline
post #2 of 8 (permalink) Old 12-27-2012, 04:01 PM
JM2001's Avatar
First thing I would check is the ground cable from the battery to the frame. Then I would check the positive cable and the ground cable from the battery box to the engine. A AGM battery has to be charged fully before installing in the bike. Don't believe otherwise. Your battery might not have been charged enough initially, up to at least 12.8 volts.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #3 of 8 (permalink) Old 12-27-2012, 04:05 PM Thread Starter
Well I had a wet battery before the AGM and it was completely dried up. Which also led me to think there was a short somewhere.
numb0617 is offline
post #4 of 8 (permalink) Old 12-27-2012, 04:25 PM
Put an ammeter in series with the battery. That will tell you if current if flowing and how much.
dariv is offline
post #5 of 8 (permalink) Old 12-27-2012, 05:03 PM
Pull the fuses and stick an ammeter in series with the fuse and see what current draw might show up. If there is something draining the battery you will now have it narrowed down to one circuit.
post #6 of 8 (permalink) Old 12-27-2012, 05:09 PM
x2 ......
post #7 of 8 (permalink) Old 01-03-2013, 12:33 PM
i the fall i replaced my old battery with a new one trickle charged over night bike ran great for a week or then hard starts all over, sat for a month went for one last ride and bike started to stall when coasting at low rpm so kept revs up a little by riding in lower gear pulled into my buddies sandy driveway letting the rpm dropand bike stalled. battery was completly dead. pulled battery today after sitting in garage for 2 month the battery was completley dried. so i think i'm gonna replace both the stator and r\r in the spring. lots of fun cheers
1991 VN 750
Mortagleus is offline
post #8 of 8 (permalink) Old 01-03-2013, 12:44 PM
A wet cell battery will dry up due to water evap as well. Personally, not a good indicator of anything.
