turn signal assembly : 3 wires colour - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 12-20-2012, 07:17 PM Thread Starter
jeankawa's Avatar
i am afraid i need info on colour codes for this turn signal, here it is:
old turn signal: 1 wire black and yellow
1 wire grey
1 wire blue
new turn signal: 1 wire black and white
1 wire red
1 wire white
so far i figure that the 2 colour one is the same but the other ones are unknown, i checked all wiring diagrams that i have and none refers to these colours.
any help ?
thanks
jeankawa is offline
post #2 of 11 (permalink) Old 12-20-2012, 07:48 PM
black/yellow = ground
gray = turn
Blue = run
dariv is offline
post #3 of 11 (permalink) Old 12-21-2012, 10:05 AM
I ran into the same thing, just swap the 2 back & forth and test it till it works correctly. You got a 50/50 shot at getting it right the 1st time.
post #4 of 11 (permalink) Old 12-21-2012, 05:52 PM
I replaced mine with Yamaha single wire signals...they rely on frame grounding...Kawi adds an extra wire to ground stuff....my single wire with frame ground, all functions work....flashers, running, turn....
PM me your email, and I can send you a really Hi Res wiring diagram (large file)....I have good net connections to Quebec and Ontario...
post #5 of 11 (permalink) Old 12-21-2012, 10:23 PM Thread Starter
jeankawa's Avatar
thanks, what does pm means, sorry kind of dumb for short forms, i will gladly do so, you seem to care about us northerners american friends. Oui, je suis d'origine francaise en amerique, mes ancetres sont arrives a Quebec en 1663,
well seems like friday night got the better of me, so far i understand that the groud wire is the same as the old one, but wondering if positive is a non issue if both my front turn signal are wired the same....guess i have to check the parallel colour code for the back turnng signal???
jeankawa is offline
post #6 of 11 (permalink) Old 12-21-2012, 11:26 PM
I believe The right signal wire is gray
The left signal wire is dark green
the running light wire is blue
dariv is offline
post #7 of 11 (permalink) Old 12-22-2012, 12:10 AM
Okiebezer's Avatar
@ Jeankawa: PM means Private Message. Left click the user's name above the thread and a drop down menu will give you the option. Return messages will appear in BOLD print on the right side of your screen near the top of the forum.
Okiebezer is offline
post #8 of 11 (permalink) Old 01-08-2013, 08:06 PM Thread Starter
jeankawa's Avatar
fixed
connected the battery back and tried my wire connections, they were reversed but ground was ok, working fine now....one more thing before the launch this spring.
jeankawa is offline
post #9 of 11 (permalink) Old 01-08-2013, 08:31 PM
...Not sure I understand this.....
post #10 of 11 (permalink) Old 01-08-2013, 09:29 PM
The wires on the new turn signals were different colors and he switched them till it worked.
