Wiring Mistery - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 11-28-2012, 01:42 AM Thread Starter
Wiring Mistery
I installed a Yuasa MF battery a while back and am very happy with it.
Now a new problem is happening!
Sometimes when I go to start the bike, the battery acts like it is dead. The solenoid makes a clicking sound. Today I noticed that when this happens the two turn signal lights on the dash will come on but very dim while I press the starter button!
I checked the voltage of the battery and it is 13 volts.
I am not the greatest with electrical problems so any help would be fine.
Sounds like to me that there is a problem with the wire harness, but where would I start??
honest Al is offline
post #2 of 5 (permalink) Old 11-28-2012, 03:59 AM
Just a regular guy
Chris32250's Avatar
Check the connectors on the battery. That would happen to me every once in a while but if I played with the battery terminals it fixed it. I finally completely took them off and reseated them with dielectric grease, and it fixed it.
"Pain is weakness leaving my mouth! *&%^$ that hurt!"
Promo code for 10% off at leatherup.com..... 55634
===2001 Vn750====
New Chrome agm battery
Ears shaved
Sportster pipes
12v adapter installed
Chris32250 is offline
post #3 of 5 (permalink) Old 11-28-2012, 07:28 AM
JM2001's Avatar
Sounds like you have a bad battery ground or a bad solenoid ground. The negative battery post grounds to the frame but also check the ground from the battery box to the engine.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 5 (permalink) Old 11-28-2012, 08:03 AM
x2 !
Battery ground connections ! Clean all ! ...Use die-electric compound (grease).
Your engine has rubber engine mounts, Your starter battery's ground is on the bottom of your engine.
WilliamTech
post #5 of 5 (permalink) Old 12-04-2012, 02:01 AM Thread Starter
Well, once again thanks for all your help!
The culprit was the battery ground to the frame.
I think that it was loose when I got the bike cause this puppy never has started so easy.
Thanks again..............you guys are always the best!!
