Help help help I just install wolo air horn no power on bike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 11-06-2012, 08:22 PM Thread Starter
Angry Help help help I just install wolo air horn no power on bike
Help please!!!!
I just installed a wolo air horn using a relay. I started my bike all good. My volt meter ready normal then I took bike for a ride I got two streets over and bike turned off and now has no power. Turn key and nothing.
Help please!!!!
hacez529 is offline
post #2 of 18 (permalink) Old 11-06-2012, 08:25 PM
romeobravo172
romeobravo172's Avatar
ck main 30amp fuse
romeobravo172 is offline
post #3 of 18 (permalink) Old 11-06-2012, 08:33 PM
Arrow
Originally Posted by romeobravo172 View Post
ck main 30amp fuse
Nothing ?
Battery connections ! ?
WilliamTech
post #4 of 18 (permalink) Old 11-06-2012, 08:54 PM Thread Starter
ck main 30amp fuse
Yup it's blown. I just checked it. My question is why would it blow it ???
Any ideas
hacez529 is offline
post #5 of 18 (permalink) Old 11-06-2012, 09:05 PM
Arrow
Any ideas
A fuse is a Electrical Protection Device. Over stress the electronics w/ current (I= E/R) , the fuse will do its job and blow. That is a good thing !
The 30 Amp is the MAIN FUSE.
Your air horn (compressor) is over-loading the bikes electrical capabilities.
hope this helps
WilliamTech
post #6 of 18 (permalink) Old 11-06-2012, 09:10 PM
romeobravo172
Could have mis-wired the relay? Dead short!
post #7 of 18 (permalink) Old 11-06-2012, 09:15 PM
Arrow
very true !
post #8 of 18 (permalink) Old 11-06-2012, 09:18 PM
pin 30 on relay should be direct to battery, pin 87 should be to accessory (horn), pin 85 horn switch, pin 86 ground.
post #9 of 18 (permalink) Old 11-06-2012, 09:28 PM
Arrow
True, I follow that.
wired Pins on the Relay !
WilliamTech
post #10 of 18 (permalink) Old 11-06-2012, 09:51 PM Thread Starter
I was doing the STUPID SIMPLE method by buying the wiring kit that is sold for the wolo air horn. I took the relay and plugged the wire kit to it. (It can only fit one way right???). The I took the the red fuse line from it and connected to the battery. Then I took the second wire and fed it through the bike and connect to the positive on the wolo. I then took the grey wire (which comes with the kit) follow it through and connected it to the OEM horn wire. I took the second OEM horn wire and connect it to a ground. And last but not least I took the black wire with the kit and connect it to the negative on the wolo to a ground. I undid the two wires from the second OEM horn and taped off the ends so no contact could be made.
One thing I did noticed was when I went to install the fuse wire to the battery the air horn went of (scaring the crap out of me lmao) so I went to the two wires coming from the OEM horn and reverse the wire connections and then made the battery connection with no problem.
Should I remove the wire kit and to the connections straight to the relay but making my own wire crimping connections and NOT using the wire kit that I bought???
Once I did noticed that the 30 AMP main fuse was blown, I replaced it and it too blew. I then removed the two wires connection the air horn and trying replacing the fuse it too then blew. I then removed the two wires connected to the OEM horn wires and try to replace fuse and it too blew. Finally, I removed the red wire from the battery and replaced the fuse and it was all good. Bike lights came on and turn the bike on with no issues.
Any suggestions I am truly grateful for them. H-E-L-P-!-!-!
Thanks
hacez529 is offline
